Swampfox
TN
Finally got everything together on Friday and worked on getting this OUO front truss and fox stabilizers on. Haven't had a chance to drive it yet but checked it lock to lock for clearance. FYI for anyone doing it with fox shocks the eyelet on the fox shock is 1.47" and the opening on the truss mount is 1.30". Had to trim some of the sleeve off to make it fit. Also purchased grade 8 bolts for the diff cover so they matched everything else on the truss. Next on the list is to get the ouo bars and mounts installed and enjoy it.
nsfr1206
I put a new clutch master/slave cylinder pre bled unit on one of the 7.3's today.
C2tuck
North Texas
Well?? Drive it yet?
WhiteMamba_Scorpion
Put some 2017 emblems on the 12. They look so much more aggressive/ classy than the original 11-16 emblems.
Front spacing 1.25", 1/2" space between emblems, total length 16.5"
Jomax
Arizona
Very nice! I chose not to have anything say diesel on my truck. Keep it low profile in CA. But that does look a ton better!
im liking that a lot!!! that looks so much better then the oem badges. just a nicer version of the 7.3 door emblem..
Sterling B.
Bryan, TX
^Those new badges look great! Now someone just needs to make a 7.3 version. :poke:
Got new tires and wheels put on yesterday. Method Mesh with Cooper STT Pro rubber. Pics to follow.:thumbup:
smcox1
Truck emblem warehouse has made them for 7.3 6.0 6.4 and 6.7 trucks.
rosspulliam
DFW
Put on the new shoes finally. Next task is to get it painted up!
2002 F250 2WD lowerd 3/4 (have another hole to go in back, might use it)
Raceline 932DM Twist Dark Tint 20x9 with +12 offset, no rubbing, can go full lock and not hit the radius arm.
Toyo Proxes STII 275/55R20 front and 305/50R20 Rear
smcox1
Looks good!
I could be wrong here but 7.3l and race truck don't belong in the same sentence. Lol
Sent from my SM-N910V using Tapatalk
LOL LOL
315/75R16 Cooper STT Pro with 16x8 Method Mesh 4.5" B.S. Rubs leaves at full lock
[/URL][/IMG]
[/URL][/IMG]
Looks good!
Sterling B.
Bryan, TX
Looks good![/QUOTE]
Thank you! Just need to figure out the hub caps... part number on the sticker in the cap is correct according to Method's web site. However... they don't fit. I can understand the front because of the manual hubs. Just cut the face open and it should be ok... but the rears didn't even go on. Going to take a look this weekend and see where the issue is. It looks like the cap isn't deep enough to accommodate the full float axle. :shrug:
