Pockets
Villa Rica, Ga
They're really bight compared to stock. You can definitely see further than before. I still have to adjust them a little but I'll do that tonight.
Pockets
Villa Rica, Ga
I didn't use that exact bulb but I did put leds in the fog lights, and also switch back leds in the blinkers. Give me a bit and I'll get you some links for what I used.
Powerstroke214
Baton Rouge, LA
Stole some LED reverse lights from work, looks good with the LED heads and fogs and recon turn turn signals I got from Josh @DD
Also tried to melt the truck down. It already runs super hot on the reduced fuel tune(1700° at 3/4 throttle). Tossed a super duty behind it for a customer. The 1/2 ton Silverado they were trying to pull it with wouldn't do over 55mph on flat ground. Naturally I drove conservatively, doing 70 up the Mississippi River bridge, probably double what that chebby would do
WILD_PHIL
East TX
Ordered a 203 thermostat and bullet housing from RCD. I'll get that installed this week.
Muskrat
Asheboro, NC
New ICP sensor, cam sensor, EB tube from RiffRaff this morning.
Checked the turbo for any shaft play. It's in remarkably good shape for 200K miles. Also checked antifreeze mix.
Then a driverside unit hub, seals and stub shaft after lunch.
lincolnlocker
Central Michigan
Installed a fuel pressure gauge and blue spring kit.
might wanna start saving up for a good fuel pressure gauge.. i have went the cheap route as many others have too and we all end up buying better.. glowchit only lasts a couple months.. also been known to be off by 10psi👎👎👎
live life full throttle
