Think like s471. With my Swamps tunes lots of smoke. Gearhead tunes very little smoke and drove much better.
Right on. Ive got little 250/200.
Op I'm suprised no one has told you to talk directly to your tuner (swamps) especially since u are using thoer parts. They know the 7.3 as well as anyone. The stick will help keep the low end torque down which is what kills rods but u never know I blew mine up and it's a stick on 40s with 250/200s and 68 fmw. Good luck with things
My pull truck has been on a 250xxx stock bottom end for a while with FFD 400/400's, gen3, a 482 with ported race cover and 220+ shot of Nos .... it's not a daily driver but it's still legal and I take it for a drive every once in a while...I snapped a BTS intermediate shaft during a pull but the motor is still going. Sorry, can't help you with the hp numbers. PS- I had a 472 with the 400's before and even with the nitrous it was still super smokey, I would definetly go with a bigger charger but drop your exhaust side down a lot to help with the lag. A BB turbo such as a GT 42 or 45R series is probably going to make a better daily driver for you than 400 series turbo because it will spool faster.
I'll Trade you your 400/400 for my 300/200.
I say Run it.. not sure if you will have enough oil but monitor it and see.. also BP..And see what its doing..
And what i would do if the 400 nozzles. Are not working out go to some 2s
I would hope to see you in the 600+ a little..
Good luck withe the build... have fun with it..
There's no single turbo that can clean up 2.3 ms of fuel from either a 200% or a 400% nozzle...so don't be chasing a single turbo that doesn't exist.
That said. ..that 468. ..is a damn tough turbo that you can rebuild for cheap as long as you don't tear up a comp wheel.
I'd just call your live tuner of choice and schedule the appointment. ...as 400% in a DD are definitely gonna need some tweaking.
And like Bruce said above. ..I'd either swap the 400% nozzles for 200%....or keep the 400% but get bigger oil in there (gen3, duals, 150+% Stealth pump)....cause you're gonna run into dc% issues with a single pump and big nozzles.
Smoker00 advice is gtg too...just run it and see....just keep in mind the points listed in my post and above it.
That s468 is gonna get lively around 1750-1900 rpm depending on tuning....but it's gonna need some help (atmosphere turbo or nitrous) to clean up 400% nozzles (even 200% nozzles)
Yes, that's exactly what a wastegate will do, keep bp in check.
I'm sure with live tuning they can make 400/400's behave, but there gonna be de-tuned for that charger, an amazing setup would be 300/200's and a gtx4294r, but for a lot cheaper the s468 fmw with a .90 housing and a wastegate would get it done. You can't completely clean up 300/200's with a gtx4294r without spray.
I say we Trade injectors )
If I was in his position I'd take that trade, 300/200's are the largest I would personally ever go for a daily driver, and for a forged bottom end.
But since it's not me and I personally wanna see what Swamps can do with this setup I say let's see what happens.
Interested in rwhp numbers and how clean they can make it run.
I honestly don't know how a SRP1.1 will handle 400/400's even being de-tuned, not a clue, but I wanna know. If it handles them well and your live tuned I wouldn't be surprised if you were over 600.
How did you know the pw of the tune?I beg to differ on the single turbo cleaning up 2.3 ms on a 200%.
I had a set of 350/200s and my charger cleaned them up to a very light haze.
Cool...Is the "light haze" the one in your avatar lolI was standing there when the tune was wrote, had several tunes from 2.0- 2.7
I won't get in a pissing match with you on this Groomzy. ...clean is a relative term.
What's the nozzle/turbo in your avatar?
Towing injectors then....300' at a timeThey were a 4to16xx/400s. Didn't make any power. I gave up trying to compete with a 7.3 in 2.6, they are about 600hp off.
What single cleaned the 2.7 ms 200% tune for you?
Maybe I missed something but why is the op dead set on running 400/400s just curious?
Yea mine threw a rod and swamps was tuning it. That's the gamble you take hope yours holds together for you. And I was running a 1.10 housing
Made 560 self tuned with that charger and 330/200's... that was with the 1.10 housing. Drivability was there, relatively smoke free, and had the tuning dialed to.where power came on around 2200. Swapped to a .91 housing and it is much more fun with the zf6. Just be prepared for it not to be as torque-y as you may like. The zf6 kinda hurts that category... but its still a fun truck to drive! Oh and that was with PW limited to about 2.5-2.7
