Sledneck57
I've run both the 71 and 72 from Elite and the spoolup of each turbo is almost identical to stock. If I had to say which spooled quicker, I would probably lean toward the 71/72, but that may just be the difference in low end power. Who knows. The 72 does make quite a bit more power than the 71. I would expect 30+ horsepower between the 2. Also, the 72 does drop EGTs 50* or so even over the 71. You really couldn't go wrong with either, but if you can swing the 72 setup, do it.
So your suggesting the 72 with the stocky hp or your 72/59 setup
