Xl headlight upgrade?
Armybyrd
Martinsburg, WV
I bought some smoked eBay headlights and they bolt in place but I'm assuming there's a different wiring piece for the bottom light to replace the sealed beam's 3 prong connector? Can anyone post pics or info on where this can be purchased?
taterthedog
Canada
What type of bulb does your new headlights take? You will need that connector. The sealed beam lights have the same plug as a H4 bulb I believe.
taterthedog
Canada
If it's a 9008 bulb, you can buy the connector ends from Ford. I believe they are expensive though. Replaced one once at the dealer I worked at because the clip had broken. It was $120 or something like that. It was in Canada though.
mn_sclb
Inver Grove Heights, MN
When I did mine the sealed bulb connector wouldn't work. I bought the 9008 pigtail from O'Reilly and used a multimeter to find polarity. Also the side marker light didn't have any where to go. So its ziptied out of the way
Sent from my MotoG3 using Tapatalk
Armybyrd
Martinsburg, WV
Does anyone have pics of the back side of the headlights? The pair I ordered don't have an actual socket or anything on the bottom part of the light.
