2011 6.7 with a 2015 turbo.....
farmin powerstroke
athens,IL
The truck still running strong, had a load of 420 bales on it today. Had to work it today sense the dyno was busy.
Sent from my iPhone using Tapatalk 2
dseitler
Royal Palm Beach, FL
I'm curious how the truck pulls @ 65 mph with that load. Can you maintain 65 mph in 6th gear without a problem? The reason I pick 65 mph is because of the lower RPM. I'm sure it does well at 80MPH but will it hold the gear or keep downshifting @ 65?
CATDiezel
I load out at 25,000lbs. No 6th gear. Locker in 5th gear and call it good. Does excellent on fuel mileage too. 12.5mpg. All day long. By hand of course.
Athens, IL
Mid 500s would be awesome. I am looking forward to the results.
That will not happen on stock fuel. Our truck with a 66mm only made 517 with a stock pump.
With 35's and 3.55's you can't pull the gooseneck 16-17k in sixth with stock turbo or the '15 charger at 65. It will do it but it down shifts on hills. At 70 it only runs 2000 rpms in 5th. 65 in 6th is about 1500, not enough to even keep the stock turbo happy. Stock tires or different gears, maybe, but not with this combo.
