Build time! S400 style
617mach 1x
pulls great, doing some changes as we speak, dropping an inch, moving the hitch notching the bumper see if that helps also going to do gears soon still debating on 4.10 or 4.30
617mach 1x
4.30s it is
Who cut vavle relifs? And how much are we talking about $ wise, I have the pistons and have a plan for the cam but I'll need .045 vavle relifs for it
617mach 1x
Morgan @ Midwest does valve reliefs
What's your plans for studs? Any O-ringing?
Extreme studs and o-rings, porting, stage 3 cams, s475, pushrods and valve spring, refreshen bottom end while I'm there
That's the plan if that what happen and don't change by next summer I'll be surprised
Drag racing this weekend so I'll see how it does, hoping for mid 12s at lease, stock trans is saying "I fkn hate you" everytime I step on it so that's also on the list for an upgrade
617mach 1x
12.99@102 was my best, with a boost leak and exhaust leak and blown hg so its wasnt so bad
need help with the lockup switch anyone got this figured out? have the diagram but cant figure out exactly how to wire it in right
617mach 1x
Ok well after this weekend she's going under the knife again,
Another turbo kit nothing like it has been done on a 6.0 before
built bottom end with a twist
Oringed heads
Stage 3 cam
Ported heads
Custom intake
Fully built/billet internals trans
Front locker/spool
4.10s (I'll have the power for them)
A/m Rear locker
Going to stay with the 275/100 and dual pump I ran this yea only going to have them flowed and have new white solinoids or wtv installed
Hoping to brake into 800hp
617mach 1x
Thanks Matt
Here a Alittle teaser of what I've been working on
TBagAMouseTrap
Windber PA
Just curious on how well a single gate works for my own build. Wouldn't bank 2 have excessive pressure with this setup? Thanks in advance.
617mach 1x
alittle more detail
thats just a baby mock-up turbo, s400 will be used for testing
617mach 1x
Thanks ford rules!
Might know where I'm going to that picture
Also my rcd 275/100 for sale 1450$ out right 1100 with your good set of injectors
