webb06 official build thread
webb06
Seneca, MO
Got a turbo ordered and being built. Forced inductions 76/92 t4 1.0 with race cover. Just like mikes except I went with the race cover just to see if it's any better.
On the injectors, is there anywhere that can take my existing injectors and clean them internally, since the pump locked up I'm sure there's trash in them, and also resize the existing nozzles I have.
Hoping I can save these Injectors before buying new ones.
webb06
Seneca, MO
Here we go again
03silvertj
It's been two days. The truck has been reassembled and has 500+ miles on it with the new set up, right?
Thats how you usually do it at least. It's been a great build to follow.
webb06
Seneca, MO
And then I picked this up tonight.......sooooooo looks like there will be a change of plans
webb06
Seneca, MO
So what's the new plan?
Swap engine from white truck in to black truck. Basically put the black truck back to as close to deleted/stock as possible and sell it.
Take engine from black truck and throw some r&r rods in it and put it in the white truck. Probably have the trans in the black truck redone with full billet parts.
Considering doing a 4x4 swap into the white truck but that still undecided.
Take off any weight that isn't needed.
Hope to have the white truck track ready by May
B585Ford
WV
Sounds like a plan. With the way you move, I can't imagine you will have any trouble having it ready by May.
powerstroked08
Pennsylvania
May? Sh!t, he's probably doing doughnuts in the white truck with the new motor now! You know his schedule, 1 hour to tear down, 2 hours to rebuild, and 45 minutes to dial it in!!Done.
webb06
Seneca, MO
Drivetrain yanked
Stock trans and Tcase ready to be sat back in.
All the other cool stuff has been pulled off the black truck so all it needs is an engine now.
