#3
907DAVE
AK
Thought I would post up some pic's of engine #3's progress.
This build features:
  • Filled Block
  • Ported Heads
  • Crower Rods
  • Girdle
  • WOP Camshaft
  • WOP Valve Springs
  • Pistons Decked, Fly Cut and Radiused by WOP
  • WOP Fire Rings
Big thanks to Jacob for getting me set up!
V-Ref
9 miles high @ 550 mph
Alaska's most powerful 7.3 is being reborn
Dave
Glad to see you posted up a thread for this.
Watching this come together, will only serve to fuel the anticipation of a how a strong and reliable runner this is going to be for you after it's all said and done.
Stuff sure does look neat, clean, and orderly up there! :thumbup:
Thanks for sharing!
907DAVE
AK
Thanks guys!
This build has been on the back burner for quite a while now, but I cant wait to have her running again.
907DAVE
AK
I was able to get the short block done today....
Holy deja vu!
Austin
Parker, CO
Did you weld those jets in place or take an extra measures to make sure that doesn't happen again?
907DAVE
AK
Yip, welded the jet nozzles to the bases and made sure everyone of them flowed okay before I put them in. I did notice that the bases were not very flat and had some raised spots around the edges, must be a result of how they are made. Regardless, they were all PERFECT before I bolted them in. Also I found it curious that they were not all aimed exactly the same, I had to dig through my spares to find ones that were identical.
JDub
Hooper, Utah
Looking good Dave. How'd the piston protrusion and valve reliefs end up? Right where we needed to be? Should make for a pretty stout little bottom end...
907DAVE
AK
Hopefully this engine runs for a few 100k. Good luck to ya.
I hope so too.
Pretty darn close, pistons are about .002 proud......but close enough for me. I need to get the heads finished up before I know how the relief's are....but I am guessing they are going to be perfect!:D
907DAVE
AK
Well the old lady is out of town for the weekend, so I got to spend some quality time with my motor.....
And here is how it looked before I decided to call it a day.....
TARM
Looks great!!!
I like the manifold hook up. No more worries of boots blowing with the v-bands. Interesting the way you welded it together. KISS principle at work. Hard to tell from the pic angle but does single welded to the two coming off the manifold attach evenly to each side or does it angle more to one side then the other. From the pic it looks like its angled off to the passenger side.
