Sagging bad with gooseneck
java
Id rather tow with a 6.7 than my 6.0 any day, put some air bags and be done with it.
KingRanch6.0L
West Houston
I bet the 6.7 pulled and handled the load way better even squatting like that. Like I said toss some airbags under it and problem solved these trucks pull great
It was like riding a bucking bronco thru San Antonio.
It did pick up speed a little quicker but thats about it.
WHY NOT
Carlyle IL
Probably because it was on the bump stops. I just made a 750 mile trip towing 15,000 lbs and I just left the cruise set on 70 for most of the trip. Never got hot and hardly every down shifted pulling up hills.
jdc753
Norton, MA
I would be curious what the door sticker says too, I didn't think you could get a super duty as light as 9,900, I figured they were all over 10k and this option was to reduce them to 10k but I guess I was wrong.
I know my 05 F350 long bed is 11,500 on the door and has overloads and I think the 6.0 short beds are 11,400?
Sagging that bad I would honestly wonder if the truck had some broken leafs, thats the only time I have seen one sag that badly.
Dave
6.0 shortbeds are either 8800 or 9900 in the 250s and 350 SRWs
WHY NOT
Carlyle IL
My truck as the 10,000lb package it is just a sticker for licensing in different states, no different than a truck with 11,500 except the sticker. Mine has overloads on it.
jdc753
Norton, MA
That is what I always assumed was the case, makes sense too.
Here in MA, if the truck is over 10k GVWR, or has 5 or more wheels, then it is required to register commercial. Some get around this, but as I understand it is how the books are written.
So instead of $25 a year for a passenger registration, and a $29 annual inspection fee, you have to register by weight, which for my 11,500 truck is $220 for the year, and usually $70-120 ($29+ 1 hour shop time) for a DOT level inspection. So in MA, getting that 10k package can be pretty useful.
SAK
Victoria, Texas
Mine has the 10k GVWR and does not have overloads. I think they only come with over loads if you have the Camper Package. Mine came with 20's stock FWIW
TXGLASSMAN
Keller Texas
well i have the 11,5 package and mine does have the camper package as well so i do have over loads
