2002 crank no start
Turbosuzuki
Louisiana
Sorry about that guys had a family matter to take care of. OK it looks like water but smells a little like fuel, I don't think it's straight diesel . I figured if fuel bowl leaked it would run out back side of engine like oil in the valley. I need a radiator because this one is cracked up top toward front of truck. Should I replace the water pump also?
I want to do a coolant flush but that should be done first correct ? I don't want to mess up a new radiator and I plan on running a oem 7.3 no aftermarket one. Any thought or ideas maybe a place to look for one? Thanks as always
Turbosuzuki
Louisiana
ToMang07
Mainah!
Nice videos that guy really shows the steps. I don't know how comfortable I am doing that work, the mechanic I went to does great work but it's seems high on prices. I guess after you add everything up it makes sense but I I'm gonna need him to do my radiator install and I don't see that being cheap.
It's not hard if you're competent to turn a wrench. Did mine last spring, inside sitting on the couch. Too easy.
Arisley
Arlington, Texas
Radiator install is easy peasy. So is the fuel bowl repair. On the back of the fuel bowl where the valve is, it is attached to a steel tube. That tube runs down the front of the motor and ends right above the cross member.
Turbosuzuki
Louisiana
Lol I can turn a wrench sorta I guess. It just takes me a long time like that job might take me several days. It's a long story but I can't stay on task if I try it's makes matters worse and stuff starts going downhill quick lol.
Lot of my buddies said the mechanic had my truck awhile to me it seemed normal for him to have it 6 weeks. Didn't mean to get off topic.
Turbosuzuki
Louisiana
It would be easy if it didn't have transmission lines hooked to it. I can't find a video showing them either. I seen a video but the guy unhooked upper and lower hoses and that was it, I was like hey what about the other hoses.
Turbosuzuki
Louisiana
Righty tighty, lefty loosey. Unscrew the old ones, screw the new ones back in the same place.
Sounds simple enough lol. I need to get fixing that fuel leak. Sometimes it doesn't leak a drop and then it leaks like crazy I don't understand it. Thanks again I will look for that rebuild kit for fuel bowl.
