2015 test mule
Jesse_01
Prince George, BC. Canada
In your honest opinions, will 2015 chargers be more or less RELIABLE at a reasonable (say 450) rwhp vs the 2104?
I think there are lots of people making 450rwhp out of a 11-14 charger that have had no issues. I know personally I have 50k on mine. Including running the high boost tune that h&s first released.
Sent from my SM-N900W8 using Tapatalk
bigrpowr
<How I Fly
Administrator
more reliable at 450 without a doubt. but capable of much more highly doubtful. BUMMER !
Breaking Habits
Mapleton, Illinois
Don't get their hopes too high. Gonna take a lot more than a wheel to make these hold up for a "lot" of potential. Maybe "some" would be a better word....
I wouldn't say I'm necessarily leaning for the 2015 guys with this statement. A reliable drop in charger for a 1st gen 6.7 truck capable of 20-30 more hp than stock form charger that is reliable, that's potential
Fast-6.0
Alamosa, CO
Is that the same size as the 2011-2014 turbine wheel. I could not believe how small that thing was. Also the original 2 piece turbine housing makes it hard to open it up to accept a bigger wheel
The turbine is the new charger is about 4mm larger, it still has the 2 pc turbine housing.
jcain
Is it truly a drop-in though? Manifolds, pedestal and dp are going to line up?
dseitler
Royal Palm Beach, FL
I have a 15 Turbo at my work and I can take pictures and post it for you if anyone wants. It will be Tuesday before I return to work. As you will see all you will have to change is the intake. Exhaust side is the same along with the mounting.
Breaking Habits
Mapleton, Illinois
Similar, yes. The same, not quite
T.R.P.
This has rustled my jimmies. I guess I'll stick to the plan of "leave it the *** alone and drive a nice, reliable, truck".
I just picked up a 2015 platinum.
4EverBoosted1
That's what I said too when I picked up my 6.7.... LOL
Honestly these chargers will not be good for big hp. Small turbine and VERY weak shaft design will be a limiting factor. We are pursuing some different options. But I can tell you with out major turbo redesign this is never going to be a 700hp drop in. Probably ever. A $4k drop in modded charger isn't gonna sell. Junk tiny hub pilot shaft and small turbine are very limiting. I'm sure there will be a plethora of drop in wheels shortly so everyone can go crazy exploding their $400 charger upgrade.
what size is the turbine wheel? would it still be a good combination to mill the compressor side out for a bigger billet wheel? or will the small shaft grenade with any size wheel change?
