35x12.50 on 22's...
Strokin6.4
Anybody have them? Been asking about 35s on 12s but everyone is running 20x12 not 22. Post a pic if you got them thanks!
Breaking Habits
Mapleton, Illinois
I run 35x13.00 on 22x10.5 on my regular cab ImageUploadedByTapatalk1354060756.707218.jpgImageUploadedByTapatalk1354060767.173149.jpgImageUploadedByTapatalk1354060774.354949.jpg
Strokin6.4
Suspension set up? I wanna run 22x12 with 35s on a 2.5" leveling kit. Hope I can get by with just pulling fender back
Jeff@Spartan
Georgia
Should be doable with the correct wheels. I ran my 35/12.50/20 Toyo MT's at stock height with 20x10's and had MINIMAL rubbing when the truck was flexing a certain way. Never rubbed on level ground. It's all in the wheels though. You'll need the most optimal offset and backspacing.
Strokin6.4
That's kinda what I was thinking too. 22x10 fuel nutz look good too
Dzchey21
wyoming
Offset is everything if you can stock closer to 0 offset they will work.
IM going to run a 13.5 wide tire but a 0 offset and only 9 wide. Should fit nicely I'll post pictures when I get them mounted
Strokin6.4
The fuels are -13mm but 5" backspacing. How's that possible on a 10" wide rim.
Spatel23
Olive Branch, MS
I run Nitto Terra Grapplers in 325/50r22 on 22x9.5 with -6mm offset and 5.49 backspacing. Dont quote me on the offset/backspacing but I think thats correct.
Tires according to Nittos site are 34.84 tall and 12.95 wide.
I did alot of trimming and run a 1inch Icon TEI spacer in front. Stock 350 block in the rear.
Here is a picture, more in my sale thread.
Strokin6.4
Yeah I mean I could always go with a 33x12.50 on a 22x12. Should look good and clear fine. Would look cool with like a toyo MT.
smokedout250
harrisburg oregon
My hostages are -24mm but they are 20s and I have 35s seems to work just fine things are really close and my truck is an 07. They are also available in a -12mm offset
Strokin6.4
Yeah I know I can clear with 20x10 -24 it's what I got now on stock height and 33s. Just not into all that side wall for 35s. Seems like 22s are no offset or a huge offset. Nothing like the good ole 10" wide and -24 offset lol
powerstrokin15
Charleston, WV
bmfs 22x10.5 is -24 or -25mm iirc. they look great 35s. and you could clear that with some fender trimming. easy.
I would go 22s if my winter wheels weren't 20s. I don't wanna lose the option of having the same tires for both wheels :doh:
Eric@HolderdownPerformance
Strokin6.4
Yeah bmfs are way too common. I'd rather run a cheaper but more rare wheel... even though fuel nutz aren't really cheaper lol
