5r110 manual tc lockup switch
kyle43335
Its just a ground to the lock up wire correct? Just not pwm?
you cant just ground the wire!!!! the pcm sees this and throws the trans into limp mode.
you have to wire it up so you can ground that wire without the pcm seeing it.
Craig@MFI
You can to just ground it...it throws the light but does not limp the trans and if your just racing shut the truck off when you done and restart it
Mike@MPD
Pasadena,MD
A simple on off switch works fine just pay attention to shut it off before you slow down to 30 and you will be fine
Sent by my Nexus powered by this (╯°□°)╯
Dzchey21
wyoming
you need a double pole double throw switch.
I see what you are saying about interrupting the signal to the pcm but I think it will still throw a code based on tc slip so I don't think its going to matter either way
TurboM700
Minnesota
Correct
If you simple tap into the ground wire the sec the TCM sees a ground on the wire it goes to LIMP mode.
What you need to do is cut the wire and set it up so when you hit the button it brakes the circuit from the TCM to the transmission and goes thru the button.
This way the TCM never sees the ground being applied to the TC lock up switch.
You could do it with a simple relay also and a push button switch if you wanted to use a smaller switch.
Redneck6.0L
done this to two different trucks, doesn't go into limp, but it does throw a light on
kyle43335
when it limps the trans immediately,especially when your trying to hold a specific gear(not 5th), IT DOESNT WORK!!
kyle43335
Correct
exactly, this is what im doing.
fordfreak4life
When u break the ground from the controller it sees an open and limps the trans to keep from damaging itself
Sent from my Milestone X2 using Tapatalk 2
Craig@MFI
Okay haven't been using it on numerous trucks for over 3 years now maybe I've just been dreaming it works
fordfreak4life
I don't doubt it does.... do u just tap a ground in or put a cutout switch in?
