5r110 manual tc lockup switch
kyle43335
here you go
2.8 was 302ft
mod was 316ft
the unvided third run was 326ft
kyle43335
I know your busy but you think you could post up a diagrahm on how to do this switch, i really need it for this weekend. Thanks man
here you are
my trucks running 225 100%,66/74,46mm gate,5" intake pipe(was pulling the restriction gauge down with the sb box(even with the filter removed.)
gutted intake mani,adrenaline billet pump,etc,etc
hope this helps
kyle43335
would the converter act normal when the switch is in the off position?
With the switch off the converter cant lock.
the switch in the down position will be normal converter operation.
And up is locked the millisecond the switch closes the circuit
faster6.0
so could there be any type of signal modulation to ease the convertor lockup on switch from toasing convertors?
kyle43335
Im sorry. I just realized i put 12k resistor in the schematic.
It a 22k resistor you need
