7.3 won't start
also need to know what icp is while cranking.. and what voltage is while cranking
1995f2507.3
It's getting low right now from trying to start it it was measuring 8.4v so I'll let it charge for a little while then try again
must have above 10.5v for injectors to even try to fire
1995f2507.3
I'll let it charge for a few then I'll report back, how should I test the icp? Just positive and negative on the posts and on 20v dc?
1995f2507.3
I got the truck started thanks for everyone's input.
need a good computer/scanner or plum in a 3k psi hydraulic gauge into the oil rail on the head.. lol
1995f2507.3
Well it's on the outskirts of Detroit it's actually very peaceful, I'm about 25-30 miles away from Detroit but the county I live in is considered metro detroit
still way go close for this cat!! lol
Endless
Check to make sure the batteries are charged up, I've had them not start due to batteries being slightly to low on voltage, bad gpr, low oil..
Edit: just saw you said you got er going. What was the problem?
1995f2507.3
The owner of the truck I called him up and he came over and he unplugged the glow plug relay so they wouldn't turn on and sprayed a little ether in her and I guess the injectors weren't getting fuel when cranking but she's up and running now I think when I shut it off it back fed the fuel to the tank from the injectors not exactly sure what went on
