Big Bore
I think the 74 turbine that the sxe comes with is what i would do.
It takes a bigger turbine to power a compresor at high boost levels.
When i had my s366 it actually made more peak boost ovrr my 364.5 with same fuel. I contribute that mostly because of the bigger wheel in the turbine. 74 over the 68.
I think with the .83 housing combined with the 63 compresor your going to be more then happy with spool up.
Dont forget, the new style 74 tubine is not the same as the old style, it responds a lot faster.
I had the uncontrollable urge to quote David Lott here. "Boost is a measure of restriction". Meaning, boost pressure is not something you can use to make a linear comparison unless you are comparing the exact same turbo. You can have less boost, and more HP, since you can flow more air for a given boost pressure depending on the turbo.
