Just curious how many guys are running a mechanical drive pressure gauge? And seeing what the turbo actual does.
I have done a TON of testing on the 6.0 and the results were pretty surprising. With a 364.5 74/.91 you can throw that 1:1 ratio out the window once you get up around 2900rpms. By 4000rpms it runs about 2:1 with 38psi of boost and 75psi of EBP (it reads higher on the street than the dyno)
But my question still stands. Does anyone monitor these turbos on a 7.3 using an actual drive pressure gauge and have any data?
I do. Green is back pressure. Red is boost.
1:1 up to 40 psi. 366sxe, 1.0 housing.
IIRC this run went up to 3k rpms (55-100 mph).
https://www.youtube.com/watch?v=OAdEvM3WVf8
This was in drive (not OD) 1800 rpm - 3500 rpm.
https://www.youtube.com/watch?v=m_vcp-AlOIA
Did you ever inquire about the gated housing. Did it look like the housing and actuator would have clearance bolts s to a T4 mount? And it was for the smaller S300SXE turbine wheel?
Never did test it. It looked like it would fit .
They made the housing for both 68 and 74 wheel. Just got to tell them what wheel you have. It was gated on both volutes also.
That thing sounds like it might be bad azz! It's cool that you have the capability, intellectual curiosity and motivation to mod these turbos that way. A 364.5 modded that way would be cool to try in a zf-6 dd that occasionally tows heavy. A super clean 350 rwhp 7.3 truck that doesn't smoke even if you lug it would be the holy grail for me. Just nice linear power. I don't want to have to go to compounds to achieve this, which is just retarded for a 350 rwhp truck. Thanks again for your contributions to the thread!I am about to be testing a some of these... I can post up some pictures if you like.
I am building a custom turbo for my 6.0 race truck.
s369sxe with a billet aluminum dual ball bearing center section. I am going to try a .83 t4 divided housing that actually gates BOTH volutes. It is a really tight fit. I am going to test it against a .91 and 1.0 non-gated housing back to back and see what it does to EBP, Boost, HP, and tq. I am hoping to have a monster street truck that makes 700-800hp on fuel only and can spray up to 900hp... but I am pretty picky with how my truck spools.
If you went up to 4200rpms you might also see similar EBP to what I was running, but I know most 7.3 guys don't run the rpms out that far.
very cool. Thanks. I imagine with a 1.0 housing I would see better, The 6.0 is a dog with that big of a housing. We prefer the .83 and .91 housings.
I know we are "theorizing" a little about wastegates. What I would want to do is run that similar setup with a 1:1 ratio all the way up to 40psi and then bleed off the excess pressure through the wastegate. I have notice on my truck (once again a 6.0) that as EBP climbs up faster than boost, the byproduct is that boost really starts to fall off.
For example I ran am s362sxe with .83t4 and 68 turbine. It would build a solid 1:1 ratio at 2800rpms at 45psi of boost. But by 4000rpms it would be at 25psi of boost and 75psi of EBP. Every turbo I have tried has the boost "fall off" even though when studying the compressor maps it should be able to maintain about 35-40psi of boost. I wonder if it is just from the turbine housing choking out so bad?
What company makes them again? When I was looking around the only ones I could come across were the t3s, and then I think finally gave up. Ultimately though, If I went to a gated housing, I wouldnt want to go any smaller than a .9, (I think the gated ones found were .83s?) because I know how well mine works with a 1.0
I am looking forward to your results of your test with both housings.
That's right. I think when I inquired they weren't available for the 80/74. They are now. ~$400. Trying to find out the gate opening size per volute. Worried on the big end it may still choke it out some.
How big are the gate openings per volute?
The brad : originally they were only available for the smaller turbine size. Same .83, it wasn't available for our turbines until last December it looks.
Yessir. 13mm seems kinda small, especially downsizing the housing so much. How hard would it be to get a .91 housing done up like that ?
