Told me you don't need a WG until you hit 550 HP.
Sent from my SM-G955U using Tapatalk
So, the SXE turbo's have no WG? That's fine I just thought they came with one, please confirm!
I think only one place makes a custom internal gate in a t4 for the sxe turbo. If you want it gated, most get it built into the up pipes. I know irate offers them.
There are a few places that offer an internally gated housing for them, but they are t3.
No worries, I have no interest in it if the turbo doesn't come with one. Apologies if I missed it in this thread-
?A waste gate isn't needed unless you're overfueling a smaller turbo.
While a wastegate will regulate boost, its primary functions are to limit drive pressure and shaft speed. Assuming those are in th green, why would you want less boost? My point was, the SXEs are so broad in their MAP that they don't need a wastegate for a majority of applications. If it's just boost you want to regulate, use a blow off valve.
Ymy comment was in response to TMCCOY not being interested in a turbo that outperforms the 38r because it doesn't come gated.
To clarify, I meant I am not interested in a WG if it doesn't come with the turbo. I absolutely am interested in upgrading to the 364.5 SXE!
