vanderchevy18
I'm trying to get the wiring done on the race truck and was wondering if someone could give me a cheat sheet. It would be awesome if someone had a wiring diagram with only the needed wires. I'm going to use switches for everything including the ignition. No key, turn signals, no heater/ac controls, radio, or anything. I want to run a power cutoff switch to the Pcm and fuel pump, and a push button for the starter. Also I want to keep the antilock brakes. If anybody has anything that could speed up the process would be helpful. Thanks!
