SouthFlstrokin'
- Joined
- May 18, 2011
- Messages
- 6,068
- Reaction score
- 0
That's what I was thinking.... I might sell the ***ker anyways lol , I really want one of them fancy 6.4s LOL
Your worse then a woman. Make up or mind!
I have only read the last couple pages. Why not just go with the old reliable setup of - 238/100's or 250/200's usually in the same price range, a 38r, RR and be done with it. You already have an ADR, and that setup has been proven to make just under 500 without doing head work. Even on down the line if you want to step up, a 38r has shown to make a good HP turbo in compounds, and the injectors depending on choice should put you around 550 or more with tuning.
That's the route I'm going. Rosewood 238/100s. LOL
I was wanting to go bigger, power wise, but started weighing my realistic uses for the truck. I tow with it, long distances, and usually in the 20k-25k gross area. The stone cold reliability of the way the truck behaved stock injectors, and turbo was one of the most important things, but I wanted to be able to put a cummins in it's place as well if the need arose. Tryin to stay within my budget, and not get into swapping rods out, etc., I figure a 160cc with a slightly bigger nozzle, good hpop, and a 38r would do just that. It seems that everybody on this site now, says go with a 250/200 and some t4 mount turbo, when you factor in the mount, good rods if you need them, and everything else, you're ~$5k just in connecting rods, and a place for the turbo to sit, before injectors, oil, etc., and then youve got a truck that can't do what it's intended for..tow, without having I'll side effects. Throw a 40' enclosed gooseneck behind a truck with that setup, and try to roll 75mph across I-44 in Oklahoma or Missouri..and tell me that egt's or smoke aren't an issue when pulling those damn rolling hills.
A 350-400rw 7.3 truck, especially a much lighter 2wd truck would be plenty of "fun" for 90% of your average guys out there, IMO.
People are towing things like that just fine without excessive egt's and smoke, with big injectors. It's all in the tuning, and with the advances in tuning lately it's becoming easier and easier. I tow anywhere from 5k or 10k to 20k rather regularly half of the year and I've got 160/30s right now, I feel that on some occasions the truck feels short on power but empty runs its ass off. I would recommend a stage I similar to what I have to anyone who doesn't plan on shooting for much more than 400 ponies.
But I want a little more balls behind my truck, so my plans are 250/200s, along with studs, valve springs, fuel system, an s400 turbo and sometime an hpop. And to continue towing with that setup.
Southstrokin, I see no reason why you couldn't run a set of 250/200s the way your truck sits with proper tuning for your setup. If guys are running 250/200 injectors with 15* and 17* hpops, stock turbos, and stock non intercooled obs turbos with success I don't see why you'd have a problem running a set with your adrenalin after they are detuned.
Out of all the injectors I have run the best so far for a great DD truck...
AC's... Only thing I would change is adding a 80% nozzle to them.
I love my 250/200, but there a bit much for every day driving. You have to drive your truck, you cant just set the cruise and go.
So you aren't TOTALLY happy with the 200% nozzles everyone seems to be raving about.... You and I agree on this.
Joe If you want to get rid of the 250/200s I know a good home for them
