Best LED headlight bulbs
c63 AMG
Are there any LED's with a good reputation for quality? Was looking around and there's a 13 page Jeep thread talking about how the keep failing.
Jassman
MS
First is low beam, second is lows and lifetime led pods, third is high beams only (have to pull the **** you switch to get both to light, passenger side doesn't work when flipping the lights to high normally)
The pics help.. I wish there was a way to compare to my Retrosoloution H-13 bulbs.. your driving lights look brighter..but my H-10 fogs look brighter
Jassman
MS
Im installing the new Putco LED's as we speak..I will let everyone know the difference between what I have in..
Jomax
Arizona
I'm trying a set right now. Way better then any I've tried so far.
This is with them and rigid dots
This is just the LED headlights
Jassman
MS
I have the Retrosouloution H-13 headlights and H-10 fogs. The fogs work great. The headlights do not cast light out far. The Putco's I just installed are definitely brighter but I will see tonight.
Jomax
Arizona
Sorry, what brand?
Retro solutions will start carrying it late February. I've been testing lights for them.
Coolest thing is the tint wrap they sell with the lights, allowing you to change the kelvin ratings.
Tint wrap
WHY NOT
Carlyle IL
Tint wrap
Pretty neat so you can make them match any other light you have on the front of the truck. On my current LED head lights the brights are pretty much worthless how do these compare and how is the cut off? Do the lights actually fit in the housing so the low beam hits the same part of the housing? As in do both of the low beams hit say the lower inner part of each head light not one lower inner and the other lower outer or anything like that?
Jomax
Arizona
They both match the same, my other lights I tested sucked in that aspect
This is vs halogens sylvania ultras on the right and led on left . I'll take a pic tonight of both leds against the garage
All I need to do still is adjust them to point lower, they're a bit to high.
dsmracing1
Alberta, Canada
What I'm really interested in is whether or not the high beams work good with the LED's. I ran a set of bright source LED's and couldn't even see the difference between low and high beam. Low beam was great though....
Powerstroke Man 6.4
Whats the lumen rating on these?
Jomax
Arizona
Never had an led where the high beams were much different then the low.
Jassman
MS
Just got home and the Putco NITE LUX Leds are what they claim. They actually work..they cast a nice long linear beam with a wide aspect..Even when I hit the brights they are noticeably brighter and superior to my other Leds. I was just on You Tube and Putco has a new and improved set of Leds coming to the 16 Sema show. NITE LUX NITRO I dont know if these are any better than Retro's led that Jomax is testing..but I am pleased..
Jomax
Arizona
Post up some pics!!!
Clean-15
For you guys using these LED headlights, do they bother oncoming drivers? Are they as annoying as an HID bulb in a stock housing?
