Buy DIGITAL brand HID kits 35w and 55w high output!
SSpeeDEMONSS
6mi from the beach, SoCal
Sorry, was referring to the 03 Superduty.
The 00 Sierra on the other hand, that is separate lows and high beam bulbs there, so that would take 2 kits to do both beams.
Thanks. My ford has silverstars in heads and fogs and I won't be putting money into something like lights for that when I don't drive it or plan to keep it.
The gmc on the other hand, I use it everyday for work so I would like some more light. Stock headlights after 11yrs are slacking. I have been thinking 5k, is that the whitest I can get? I don't want any yellow or any blue/purple.
Garrett
Probably getting paid at work to post this from my D1
retrosolutions
Garrett
5000k is a warm white, if anything a slight yellowish tone.
6000k is a cool white, if anything a slight blue tone.
Given the choice between the two most people would pick 6000k as the "more white" color.
For those lamps on the Sierra though, you only need to do the low beam kit, in most cases there would not be much benefit doing the highs as well.
retrosolutions
No Gimmicks, No gags!
Benefits of our kits:
- Fast shipping in the USA
- A REAL lifetime warranty
- proprietary equipment
- no gimmicks, no gags, no bull
- real customer service
- real technical knowledge and help if needed
- quality, reliability, and longevity
CLICK HERE TO ORDER! USE "PSA" Discount Code
REGHARDWARE
These exclusive kits feature 55 watt high-output DIGITAL ballasts. At 55 watts of true power, these ballasts will offer more light (30 - 40%) than any other HID kit on the market! Ballasts are 100% digitally controlled, which allows extremely high efficiency, low starting current, and low operation current. This all means super reliability, better longevity, and 100% flawless plug up and bolt down operation on all cars, trucks, and other vehicles. Ballasts are water proof, dust proof, vibration proof and feature instant hot re-strike technology to protect already warm bulbs from excessive damage when restarting.
Bulbs featured in these kits are the best among all kit manufacturers, with the least variance available on the market, all within +/- 100 lm (brightness) and +/- 200K CCT (color). Average lifespan rating is 3500 hrs, compare to others of significantly less! Focal points on these bulbs are the best we have ever seen in any other kit, resulting in some of tightest and most uniform beam patterns to come from converted lamps. The resulting beam pattern is UNMATCHED by any other kit we have EVER tested!
All items are brand new, packaged in sturdy aluminum cases for ultra-safe shipping!
CE safety listed, ISO registered manufacturing, E4, E11 TUV mark available. All genuine parts are individually serial numbered.
Each kit inlcudes:
- 2x DIGITAL waterproof 55 watt ballasts
- 2x 55 watt HID bulbs
- 2x plug and play pigtails for your application
(Bixenon High/Low beam kits include fully integrated plug and play harness)
- mounting hardware
- attractive metal case
- Lifetime warranty against manufacturing defects on all ballasts and bulbs!
All bulbs types available: H1, H3, H3C, H4/9003, H4/9003 Bixenon*, H7, H8, H9, H10, H11, H13/9008 Bixenon*, 9004 Bixenon*, 9005, 9006, 9007 Bixenon*, 9145, 5202, D2S, D2R
* Bixenon options are more expensive
Colors available: 3000k, 4300k, 5000k, 6000k, 8000k, 10,000K, and most types in 15,000k*
*Less common bulb types and colors are available by request, most applications have these in stock, some are special order.
Hours: Mon.-Fri. 8am - 4pm Eastern Time
Telephone: (860) 655-2501
EMAIL: [email protected]
IM on MSN or AIM: retrosolutions@cox. net
All text, images, and other media are protected under copyright 2011, do not copy or post without written permission from Retro-Solutions, LLC​
UpstateDieselGuy
Mayfield, NY
I will be ordering soon! I will be doing my Head and Fog Lights. I would really like to put some in my plow lights, but I don't know if even the slim ballasts will fit.
Chris
retrosolutions
My truck and a buddy's '08 cummins outfitted with retro.
Nice shots, thanks for posting JD!
Chris
Thank you Chris. Let us know what you are working with there, as we can suggest the best way to set it up accordingly.
retrosolutions
It is the newer Fisher Intensifiers. I figured that a slim ballast may fit in there!
They might over to the one side where the amber bulb sits there. Even if not though, the ballast can always be installed externally, and in fact, for the sake of lifespan it will probably fair better.
02BigD
Coastal NC
So for a 02 truck that has 05 conversion on both headlights and fogs, what would be the correct 55w option for the headlights? Is there a specific fog light that I am missing.
retrosolutions
That's what I was thinking. Besides, that's what grommets are for.
Correct you are!
The headlamps you would need to select an H13 bulb kit option and then under that would be a selection for "97-04 Ford Truck with 9007 wiring" you would want to select as well.
For the fogs lamps, a 9145 or H10 application would be correct for the bulb/kit type. However, you want to add a relayed wiring harness for the fog lamps as well.
retrosolutions
Each kit inlcudes:
- mounting hardware
retrosolutions
Happy Holidays everyone!
Have fun, please don't fight with family (just one day!), and most of all please be safe!
retrosolutions
PLEASE USE OUR NEW WEB STORE FOR EASIER ORDERING!!!
Each kit inlcudes:
- mounting hardware
