Downey
What tune was the truck on for first Dyno run? What tune will next Dyno run be on?
Nice. Will be good to see some final numbers. You know you're doing something right when all people do is line up to piss in your cornflakes. Cheers!
I wish we could do a cam just back to back. But we have a cam from Straub that I just put in the truck this week with a 62Non vgt and full fuel system with 190/75. should hit the rollers next week. See how she goes.
How's it run?
To be clear on this. Before:
Stock 6.0L
Stock Turbo
Stock Injectors
Stock Camshaft
White Rain Extreme street
4 Pull from 309HP to 330HP, average was 320HP
On Friday it will be dyno'd as the following:
Stock 6.0L
Stock Turbo
Stock Injectors
Straub Camshaft
White Rain Extreme Street
Same Dyno Same Operator.
Then it will dyno'd with:
175 Stock Nozzles
Stock Turbo
Jessie Warrens Tuning
I am interested in the findings of this. My 06 is still bone stock and just in the planning stages of what I want to do.
Stock 6.0L
Stock Turbo
Stock Injectors
Stock Camshaft
Stock 6.0L
Stock Turbo
Stock Injectors
Straub Camshaft
175 Stock Nozzles
Stock Turbo
Well what do you think?
Andy and jesse had it up on the dyno last night and the numbers I was told was 556hp an 115X I didn't get to drive it on the street. it also had more in it but jesse had to pull PW back as it started dropping ICP. This is also on a ZF6 truck.
By giving the engine what it wants when it wants will make for much more efficient engine. This will in turn make the engine want more.
The pump had almost 200k on it.It started dropping ICP with 190/75's? 190's should hold ICP without any issues. How healthy is the hpop?
You just described most of the women through my life!
Stock 6.0L
Stock Turbo
Stock Injectors
Stock Camshaft
Stock 6.0L
Stock Turbo
Stock Injectors
Straub Camshaft
175 Stock Nozzles
Stock Turbo
