Did some tractor stuff to Chris huh?!
Looks like the first run was started late and didn't come on to boost until mid pull. That's why the torque was so much higher in the second
From what I have seen in the aftermarket diesel and how I have been taught to drive a turbo with exhaust velocity, I feel the cam will drive the charger harder and much quicker. For the guy that wants to work the truck during the week and go drag racing or truck pulling on the weekend this cam is dual purpose and will do both. I will maximize power in the rpm range from a stock tune to a max effort tune as the cam is working with the engine, not against it.
If another benefit is increased fuel mileage and in this case a 29.5% increase then it is even better for the end consumer.
The only thing I have in mind for the Cam is since I use my truck strickly for pulling on a normal night the pulling truck is running in the RPM range from 3600-4200 RPM's whats your thoughts on that?
How is the customer liking the truck with the camshaft in it?
That's a really broad statement. Would you be willing to post your lift/duration numbers so that a comparison can be made?
Cam is under .360 lift on both intake and exhaust and less than 190 at .050" on both intake and exhaust.
