Super08Duty
Ive started my own Thread so i didnt further hijack MPD's thread. Got everything done and picked the truck up today. On the way home the truck drove great but not as i expected. Im running erics tunes and at the time had the xtreme street on the truck with firmer stock shifts. cruising at 70 boost was between 4-5psi and Egts were right at 800. rolling into the throttle until the pedal hit the floor i was only seeing about 35psi of boost. Got home and started messing with the tuning. Loaded the Extreme Race and Race Lock then took it out for another test drive. Completely different truck. Ran like a raped ape until it locks up, Then the turbo chirps hard and dumps boost, tryed getting into the throttle slowly and it wont build more then 5psi of boost, look behind me and the roads gone, completely black. Retuned it back to where i had it leaving houston and same story, Ive sense retuned it a good 5 times with the same results. Im not sure whether its my tuning, the wastegate, or just simply too much fuel. Other then that its a great kit, looks and performs very nicely. Little laggier then i expected but not terrible and still street-able. I would recommend a muffler if your running a stack because this thing will cause hearing lose. Any thoughts as to what might be happening would be greatly appreciated. Ill post pics tomorrow and Vids when i can.
