nvme_63
without hijacking could someone give me a quick run down on how the ports work on these wastegates? im still learning also on external gates.
http://powerstrokearmy.com/forums/showthread.php?t=1834 Here is some info to read,, should explain it.
I like the idea of regulator in cab. Id be all over it if I could come up with a VERY clean way to do it.
Hey super08duty... I'm trying to put my single kit on... What did you do with the oil drain hole that's on the pedestal? I am imagining that the one in the pic with the wire tied around it is the one your using for the turbo drain.... Did you just plug the other one?
Blocking off the WG until the plumbing gets here. Also sent my Livewire in to have it updated and possibly tweak the tranny tunes. Well see how it runs with the gate not venting out both sides. Hoping the hose will hook up to my CFM port that way i dont have to take my CAC pipe off to weld a new bung in.
Did blocking the gate work?
Any updates?
Sent from my DROIDX
