- Joined
- Oct 3, 2012
- Messages
- 11,842
- Reaction score
- 33
There are trutracs around that have held a lot more power than you will be making. Also, they won't have the issues that you just mentioned in your post
I have not thought about the grizzly locker yet... but I will look into it.
Have you had bad experiences with tru trac? I hear mostly great things about it... why would you call it a paper weight?
I am leaning that way... hoping to bring the truck down to you guys to install it next week if you have a slot open.
I know what you mean about the locker vs lsd debate... but I don't see it talked about with Ford Superdutys. I have been jeepin most my life and have ran many different types of lockers in many different jeeps. It was perfect for rock climbing but gave characteristics to the jeep that I don't want in a DD. I have been told that you don't notice it as much with a longer wheel base, but I don't want to take any chances. I hated the chirping around corners when going to fast, random pops out of the rear end when the locker unloads, pulling out of the curve when I accelerate around a corner... etc... etc...
BUT>>> I also don't want to end up with an LSD unit that cannot hold the power. Hope that makes sense.
bullchit
I call bs too. True trac gives you everything you want/need with no negative side affects.
That doesn't happen to often haha...
Black Market Racing. I helped them install their AWD Dynojet a little over a year ago. It's a bad ass dyno that should be able to load our trucks well. I just need to see if our trucks will physically fit in their dyno room. Bartling is a good group, but I don't think they can load their dyno well at all. Not sure if it is the dyno itself, or the operator. I haven't been to Dyno Chip in years. They used to not be able to get an RPM signal on diesel trucks, but I know they have since upgraded their equipment.
I hit mine with a hammer till it quit.
