OBS picture thread:
oneton
fla
Heres some of mine
what are the specs on you wheel and tire combo,any lift?
samoht517
Lakewood, CO
They are 20x9 5"bs BMF Novakane 8 stealth black, wrapped in 275/65/20 nitto terra grapplers. Rear is lowered 2 inches and the front is stock. The fornt bumper is trimmed a tiny bit. Its the only obs ive ever seen with BMFs
oneton
fla
thanks.looks good.i am wanting to put some 20's on my truck,but cant decide which ones to go with.
i did mine like you lowered the rear,now if i could only get the front down a couple of inches
samoht517
Lakewood, CO
They are nice wheels but at 400+ a wheel I would never pay for them. I knew people and picked them up new for around 700 for all with 50% tread tires. As for lowering the front ive been thinking about getting hydraulic bumstops so i can get rid of the factory bumps and go down a couple more inches. Also thought about notching the frame.
psdguy95
Effingham, IL
Its kind of pieced together.. they're tough country 2.5 add a leafs on 250 hd springs ( mine were not the hd springs ) and a factory F350 block in the rear (required new ubolts 14in long 3 1/2 wide on a round bend ) but it brough the front up like crazy cause the ttb has a pivot and as you push down on the outside it creates camber so the drop helps bring the pivot point down to the level of the springs.
Couple of the springs and camber and how much of a difference it made on my truck before the blocks
Got it. Where do you get the drop bracket from?
littleredstroker
where the antelope play
yeah truck n trailer both ere like 31-32k i cant remember. if you look at the drives side truck bed and back door u can see where he got sideswiped but a truck with a snow plow, hes got stage 2 inj and a intercooler and that sucker can pull a trailer.
