Powerstroke214
6" is too small for a stack IMO
That's how I did my 7 inch miter on my black truck, slightly shorter than the cab.
There are alot of trucks here with stacks above the cab and I'm not a fan.
But on your truck duals would look great.
I'd want a custom set done. 5 inch stainless no tips.
Sent from my SAMSUNG-SGH-I537 using Tapatalk 2
Whatever fittings you use, try to stay away for, Russell.
I have had everything from the -6, to the -12 crack on me.
The nuts crack. Can't see the crack until you smell fuel, and then try to tighten the fitting up...the nuts will then spread open like a cheerleader. (Junk)
I pmd marty.
I'm just not sure on the fitting size of my rr feed line. Should be 5/8ths right?
from where? tank to pump 5/8" is sufficient, but -6 from pump to motor is just fine.
No need for more than that. Plus its a lot easier
Hellen Keller sent this?
