SRP1.1 failure
DocBar
Akron, Ohio
50 for shipping? Man people need to get more creative with flat rate boxes. I shipped a full set of injectors from CA to TN for the nice low flat rate of 11 dollars....
What kind of padding were you able to give injectors for that price? If it fits, it ships is great and all, but getting damaged goods just to save on shipping really sux.
JSchuricht
AZ
I completely agree. Properly packed items should have at least 2" of protection all the way around. You should also be able to use the box as a soccer ball without damaging the contents. You don't want to have to deal with USPS on a damaged item, it sucks and cost me over a month during my build.
backwoodsboy
Merica
...and me a set of cores...
Milford
Plainfield, IL
They were cores. I had tons of bubble wrap in it to and each wrapped individually. I just covered the whole box in tape to keep it from closed. USPS didn't like it but hey, it fit.
I rebuilt my new ipr and the orings all looked fine as they should. The ipr is about three months old and the orings were all good visually but I replaced it all anyway.
The oil leak did not change. Its originating from the front of the motor. The valley is holding oil. Right up near the hpop. Ive had people throttle the motor as jake(linc locker) suggested and watch and i cant see the oil leak. It must only do it +2k psi under load. The oil sitting in the back of the rear cover is pointing toward this same fate. Im gonna have a crazier buddy come.by and powerbrake it while i stand(i know, bad idea) on the front bumper and look at the oil pump.
Ill keep this thread updated. Love the pump but haaate oil leaks, especially considering I pulled my motor to fix them all and replace the oilpan.
vanderchevy18
Benton, Ks.
Dude. You need to clean everything in the valley till it is spotless. Perfectly clean. Then look. I had a truck that I couldn't find the leak on to save my life. Turned out to be the oil bypass spring plug. It's the plug in the block on top to the right of the resivour where the hpop mounts. It took me completely cleaning the engine till it was spotless and getting a second set of eyes before I found it.
The valley is spotless! Its bright aluminum silver too. Theres oil in the back of the hpop on the.cover and in the helicoil groove. Theres a drop on the top of the case of the hpop but when I clean the front two divots out in the valley I take a new rag and wipe under the pump itself and its always clean. The lines are new and wrapped in loom. Ive taken the loom off and its clean in there. There is no "trail" either from it running down from the source. It doesnt do it always. If I start the truck.and the.icp.stays low it will clean in the valley. After 2k psi, forget it. You're gonna get drips.out the drain in the rear of the valley. :shrug:
Where is this plug again?
Turbo Man
Marseilles IL.
Try cleaning up all the oil and then pack the area tightly with rags or paper towels. Go for a ride to get the pressure up, then come back and slowly remove the towels. You should find a wet spot on the towels and that should show you where the leak is coming from.
Yea, thats kinda what we tried initially and the bastards were soaked. Worth another try though. This time, more towels!
First I need to go and take back my two week old starter. It had a hard life,lol. It quit working last night. This is number 3 or 4 since June. :doh: gotta love oreillys in the last two years...parts got super.crappy.
Milford
Plainfield, IL
Get a Ford OEM. I have had horrible luck with autozone starters. 2 in 4 months and I said screw em. Got a Ford one and its been going for 4 years now.
$400=no thanks.
You can buy the mitsu starters for 260 w/o the stupid motorcraft sticker on it. I returned mine, gave em ten more dollars and got a brand new mitsu.
If this doesnt work Ill buy one from mean green, dc electrics, or have a local guy just build me.a starter to.certain specs.
Milford
Plainfield, IL
I don't pay the sticker prices per say on Ford OEM stuff. My pops is a mechanic at the local dealer so everything is at cost.
Turbo Man
Marseilles IL.
I have a dealer account also, Ford dealer parts are not much if any more than the average auto part store. OEM for me.
That's all fine and dandy for you two but they try to pound everyone else in the ***kin butthole. So piss on em.
Milford
Plainfield, IL
LOL if you were in my area of the country I would say let me know what you need. You could go visit my dad and he would get you whatever you need.
You are fairly close.but I have given up on the dealerships. If the parts store cant.get something decent they can usually get Motorcraft bs too. If that doesnt work I go to the internet.
old man dave
Petaluma, CA
Places like RockAuto.com sell Motorcraft for good prices. Also Amazon works, too.
You can get an additional 5% off at RockAuto by going to retailmenot.com and finding out the current discount code and entering it into the "How did you hear about us" box at checkout.
