The 2011-16 Leveled Super Duty Thread
Cesar84
Oklahoma
2.5 ready lift with what i think are 5" blocks in the rear with 20x10 fuel kranks on 35/12.5 nitto trail grapplers
Cesar84
Oklahoma
If the ? Was for me no i have no rubbing at all until it is at a really bad angle but no rubbing otherwise
DoubleLung
Not as of yet little plastic trimming and she's all good
Stackedup6.7
What's the weight of your fifth wheel? You have a lot of miles on hauling it with that setup?
WhiteMamba_Scorpion
Carli leveled with Bilstein 5100s, OUO ALAs, OUO track rod joint, BD diesel adjustable track bar, Fuel Mavericks 18x9 on 35" MTs.
2wd valence and steps removed
4wd valence and oem steps
Pstroke14
Should I be able to clear 35's with just 2inch spacers on my 2014, I really didn't want to change the front shocks yet only got 30k on them ,
Squat and Poot
Houston, TX
on stock wheels yes, some have reported radius arm rub.
I'd recommend a shock/coil change as they will help the most with ride comfort
c63 AMG
Any advantage running an adjustable track bar over a drop bracket?
UNBROKEN
For just a level kit I don't think so. My axle is dead center at 2.5" lift in front with a Ready Lift bracket.
spooledplatinum
Kinston, NC
2" block in the front, Fox 2.Os. 2" blocks in the rear. 22x12 mavericks on 35x12.50 Arturo MTs
c63 AMG
Is there any adjustability with the bracket?
