Squat and Poot
They're worth every penny though...
love mine
Ive been reading about them, and I haven't found a bad review yet. Everybody says the kits ride amazing, especially when adding in the leaf pack in the rear. Do they really make enough difference to justify $2000? If I decide to buy a Carli kit instead of tunes, then I think Im leaning towards the commuter kit. Seems to be the most reasonable for what I would use it for. I just cant see, to find any info on spring rate comparison vs stock. If I want to tow anything, looks like Im going to need to invest in airbags....
So if I go with the Commuter 2.5" do I still need to purchase the 5" rear block to level it out or does the add a packs do that for me?
No. you will need a 1.25" block to make a tiny rake. Some guys run F250 blocks but it sits too ass high for me. But with no block at all, it looks like a chitting bulldog.
LOL! Definitely don't want the chitting bulldog look. Where can I find this 1.25"
block?
If a guy had access to a mill I'd imagine you could make a 1.25 block from a stock one pretty easy
Let's put it this way: How can you NOT justify 2-3k on something you will deal with EVERYTIME you're in your truck? Suspension is a big deal, and I'd argue it's one of the most benificial mods you can do to your truck. I will NEVER understand why anyone would go cheap in that area.
Also, for the uninformed: Until you get up in the 3.0 shock range, ALL Carli hardware is the same, the only difference is the shock package. So you can buy the coils, track bar and add a packs, for about 1-1.5k. Shocks are anywhere from 600 for a set all the way to 4K a set.
Please direct me to where i can buy the product that cheap?
Ditto!
Sent from my banana using Tapatalk
Do you have a VOA account?
Just ordered my rims and tires yesterday, getting ready to pull the trigger on a Carli 2.5" coils,shocks,adjustable track bar and caster correction shims. Anyone know if I put the leveling kit on with my stock rims and tires and get a front end alignment like the kit says will I be good to just throw on the new rims and tires when they come in even tho they are a different size?
