Wheel/Tire Tech Thread
slightlymodded
Fort Lauderdale FL
My 6.0. F350 4x4 with rear block removed, stock front, 2" wheel centric wheel spacers, lariat stock 18s, 275/70/18. No rubbing beautiful stance. (Had to shave the nipple off the wheel studs on the front, they were a hair to long and wouldn't let the stock rims sit flush, to run stock rims GET WHEEL CENTRIC SPACERS, or you will have a rough ride)
In the middle of doing an overhaul on the truck, here's the stance now.
F350 4x4, no rear block, 2.5" leveling kit donuts on front coils, 2014 stock king ranch 20s wrapped in new 35x12.50/20 mud grapplers, on 2" wheel centric wheel spacers, no rubbing so far, haven't drivin it yet though.
Loving the more agressive stance so far
Stroghty
I have just read through most of this thread.. Some really nice looking trucks!
Right now have +40 offset 35x12.50x20 stock height with no rubbing anywhere
I just bought some fuel nutz 20x10 -24 offset with Nitto Trail grappler Mt. I have 2011 f250 they are going on stock height. I am considering 2.5" level kit or 4" lift. If I decide to go with 2.5 level kit will the tires rub? How much will stick out? Thinking of some bushwhacker flares to hopefully cover them up.
Here is my truck now and the new wheels I just picked up to go on it this weekend.
05f250harley
I have 20×10 -24 fuel mavericks with 35/12.5/20 toyo at2. I'm on a 3" lift. It rubbed a little.
coppertone6.oh
Rome Ga
Ok guys new to the group and I've read his entire thread. I'm looking for definate answer. I have a 2005 KR With 2.5 leveling kit running 35s on stock KR 18's they barely rub control arms at full lock. I'm ab to pull the trigger on 20x12 -44 fuels with 35x12.50 fuel mt's. Minor trimming is fine but I'd rather not get into cutting sheet metal. What do you guys think? Will it work? Anyone have pics? If no what's the biggest tire I can run? Thanks in advanced! Awesome forum!!!
bft blue oval boys
Burlington, NC
That will scrub bad with that lift and will require a lot of trimming. You're going to need at least 4" to clear 35's on 12 wides.
black'n'blue
It's gonna rub. I have 22 x 12 -44 offset with 36 x 12.5 tires and it rubs with a 6" lift. I also had to cut the inner fender well and trim the lower fender at the bottom where the stock fender flares are
coppertone6.oh
Rome Ga
Well that sucks. I think 33s just look small on our trucks. How exactly are you guys cutting the fenders? Surely someone has done it with pictures of the damage.
black'n'blue
The first pic is of the wheel well. The second is the stock fender flares and the fender. The third is the front piece under the bumper
Stroghty
Put them on. Had to modify the front lower bumper basket on both sides. Also had to trim inside the fender (the felt) on both sides. No scrubbing now. Completely stock height. Wheels 20x10 -24 offset 35x12.50 Nitto grappler MT's. Looks really good in person. Adding flares and 2" level kit next week...
coppertone6.oh
Rome Ga
Thanks for the replies guys. I want a nice stance, with as much rubber as possible with no more lift. Any suggestions? 20x10s with 35s?
ford_muscle1
Fort Lee, VA
So I am ready to get some rims and tires and finally found rims I like. So I was looking at the Fuel Trophy in 20x10 they have -18 offset and 4.75 backspace. Part number is D55120001747. Was going to get 35x12.50-20 Nitto Exo Grapplers for tires.
So the truck is leveled 2.5 inches and currently has 325x65-18 on it and they only rub on the radius arms at full lock.
So does anyone think I will have any issues with this setup? I have to order the stuff since I can't find any shops local to me so trying to get this right the first time. Thanks.
thumbo88
kentucky
i have 20x12 with a -44 offset stock height was wondering what size i could go with and not look like crap
slightlymodded
Fort Lauderdale FL
F350 4x4, no rear block, 2.5" donut leveled front (It is leaning). 35x12.50 nitto mud grapplers on 20 x 8 stock 2014 king ranch rims with 2" wheel spacers.
Small rubbing at full lock on bumper lower valence, Inner fenders are ziptied back, no problems there.
ford_muscle1
Fort Lee, VA
Nobody has any thoughts on this set up?
bft blue oval boys
Burlington, NC
I think you'll be fine with that setup. May have to trim a little but probably not much.
On second thought, what year is the truck?
