Rudy's sct sf3 review
Strokin&Smokin
Louisiana
That is all
Sent from my iPhone 5s using Tapatalk
soooo.... been having issues with my gallons used vs actuall used so i thought i would play with the tuner some and try to get it close to stock as possible... i took it out of the extreme tune and was gonna load another tune.. it says i have a tow, street, street firm, performance, and extreme tunes.. well, im certain i dont have a tow tune cuz it doesnt even let the truck run and codes come up for the exhaust crap that was deleted.. no biggy.. so i loaded the street tune and it took this time so i am trying that out right now.. it feels super close to stock so ill leave it there for this trip out to buffalo... the street tune is responsive like stock and only boosts about 22-23lbs which is what it did stock... power even feels the same.. it does blow a pretty good plume of gray smoke on takeoff but clears up instantly... wont go much over 100mph cuz fuel isnt there but we will see how it works out and see if the gallons used on the dash gets closer to the actual gallons filled with.. its kinda boring and stockish but it still feels good.. be WAY WAY better for the turbo too..
Strokin&Smokin
Louisiana
What was you boost going up to on performance? 25 is the highest mine hit
Strokin&Smokin
Louisiana
25ish but on extreme it hits 38 easily.
Turbo will not have a long life at 38 homie. Whatever they changed on mine has it maxing out at 25 on performance which is great. You might however getting more power out of yours than I am.
LovetheTide
Fort Worth
You sure it's making that much? I hardly run mine on extreme, much less get to full boost, but it seems as if 28 was the max I've seen.
Stangr8cr
38 is crazy high for that turbo, mine would see 32-33 playing around once in a while and my turbo took a dump at 21k. Tuned from 3500 miles and not real hard on it. Truck will run WAY nicer with a 15 retro kit though...... :rockon:
Keith
hey dip****, im the one that told you that... and do you even have punch it performance tunes?
needle width off of the 4 on the boost gauge and my torque app records highest psi too...
Keith
yeah. i played around for a while but im gonna keep it in the current tune till i have that forced upgrade moment and I'll be calling Morgan@Midwest....
LovetheTide
Fort Worth
You have to be running different tunes than I am. Is there somewhere in the settings that shows what version or update we have?
