My 6.7 venture
Athens, IL
Thanks guys! Got a chance to run it on the dyno.
Mad 783 on fuel and 1016 on spray. The last run it was getting heat soaked and also blew an egr coolant line....
Central Illinois
Damn man! I guess I may have missed this, but does this still have the stock rods in it? And did you put a wastegate on it? Very impressive especially for utilizing the stock appearing VGT!!
Athens, IL
Yeah, since it's been so long in this thread, I'll recap. Engine has R&R rods, balanced with a stock balancer and 2015 crank. It has coated pistons, coated bearings, new ford front cover and oil pump. Factory oil cooler. We ported the heads, hd springs, hd retainers, HD pushrods. Ported intakes. 100% Exergy injectors (no one at the time had ever made any that big) it has a stroker cp4 pump in the valley, and a 10mm cp3 on the belt. It has the 66mm vgt with a 70.5 mm turbine. And it has a 38mm wastegate for now.
Central Illinois
Thanks for the clarification man. It has been a while in this thread! Also, I noticed you mentioned a 2015 crank. Is there a benefit to the 15 crank vs the 11-14? Never heard of anything about that until now.
