My 6.7 venture
Athens, IL
How much boost was it registering on the fuel only pull?
On the dyno, I'm not sure. On track about 44-45
Thanks for the clarification man. It has been a while in this thread! Also, I noticed you mentioned a 2015 crank. Is there a benefit to the 15 crank vs the 11-14? Never heard of anything about that until now.
Newer part number. Rumored to be stronger. More importantly supposedly have the fixed the casting defects that some the early cranks had.
02bigstrokin
Damn you Morgan! Lol This is not good for the wallet at all. Makes me want to say hell with the lift and go fast again. Haha
Jomax
Arizona
I choose the go faster in the desert this time around. Soon it'll be fast on the street. A good friend of mine just bought the H&S turbo kit. Now I need to do something lol.
devdiesel
Barrie, Ontario
Damn straight he did! I was lucky enough to be right behind him in the staging lanes... But his excitement after was priceless lol
Breaking Habits
Mapleton, Illinois
Post 10 second pass.. 8 blue moons later
We celebrated like bosses that night.
Luh yew punkin
Athens, IL
Went to the dyno to see how the 66 does compared to the 68. Made within 10hp of the 68's best run on the same tune same dyno. So James has decided that we are going to run with the 66 for now. The 66's driveability is much nice and lower cruising temp along with making nearly the same exact power makes that decision easy. After that we turned the wick up on fuel and were able to squeeze a few more ponies out and get the fuel number to 746hp! Which is absolutely getting it for the single 66.
Also tested the stock and no-limit intercoolers back to back. Total peak power was nearly the same. But we saw the factory cooler have a 2psi drop across it. The no-limit only had a 1psi drop. Also the torque came in sooner and makes for a better punch off the low end. I'll dissect the numbers and datalogs more tomorrow.
Then we went for numbers.... Kicked the fuel up even more, and hit it with a 110 jet.... 1048hp which was cool but I wasn't gonna stop at that. Seconds stage broke us in the 1100 but we were going for everything it has. Put two 136's on which basically do nothing as I only have .120 solenoids. Tried our best making four 11xx passes. Topped out at 1174hp! Nearly 420hp worth of spray lol.
shmoozer
Nice job Morgan! Those are some hellacious numbers for a single 66!
-KCCO-
Athens, IL
All those runs are un altered (no dyno jet factors) on their brand new mustang power dyne 2500 hp loaded dyno.
On edit, I'm waiting for a call back. But last time we ran the straight uncorrected was higher as we are 500' altitude here. Just looked at the sheets as they do show "WC" on them.
HD F250
Washington DC
That's awesome numbers Morgan! Glad to see the 6.7 really starting to show her potential. I think I will have to get in the game soon.
