Terrible mileage
6fourstroker
Damn maybe it's bc of the single set up? Mine on factory compounds, deleted, 5inch Exhaust, s&b filter, and 32inch tires running gearhead hot street tune I get 18.3
SEABEE08FX4
Montgomery TX
With my S366 my mileage went up buy about 1 MPG, when I switched to a S371 it stayed the same maybe slightly less. Not sure yet what will happen with the S467 as I haven't finished it yet. But generally you usually gain a little mileage from a single swap.
Radioflyer
Pretty much same differences I saw with mine.
I 6in lift, similar tire size, and bumpers as the OP and my S371 got the same mpg as my stockers did, and the 66 went up a little like eric said. Averaged about 12-13 no matter what I was doing on all 3 setups.
Went back to stock height, 275's, stock bumpers (as it sit's currently) and i got about 14mpg consistently around town and best i saw with the 66 on the highway was 18 when i caught a day without head wind. stayed normally around 16 (80mph is our speed limit). With my GTX, seeing about the same but playing with tuning still so I haven't really been paying much attention.
St. Louis Park MN
His do ya like the hot street tune?? I'm running the street tune, gonna try out the hot street. I got the tow, street, hot street and race, I've only ran the street so far.
6fourstroker
The hot street tune is awesome.. Haven't used tow or street yet.. But hot street is great. I've used race a time or too but don't wanna stretch my studs lol.. It opens up a lot more when boost hits.
drunk on diesel
I've been running the race tune for a couple hundred thousand miles between a few 6.4's. I wouldn't loose any sleep over stretching "studs"
SEABEE08FX4
Montgomery TX
There are trucks out there running large turbos, injectors, dual pumps and much much more aggressive tunes who aren't stretching studs. I wouldn't sweat it.
Powerstroke Man 6.4
Working on it now
My engine and trans tune took about 4 reversions. The truck started from having no bottom end laggy and had no power climbing hills high cruising egts. to tapping the go fast pedal and boom I'm gone LOL.
Matt worked some magic on my tunes and I love it.
cow killer bumper = -1mpg
light bars = -1mpg
4.5" lift = -1mpg
mud tires = -2mpg
dirty smokey tune to try to get 66mm turbo lit = -2mpg
it's not a magic formula :eek:
The obvious, unwanted truth. In certain cases a little drag created by tires of larger size is welcome but in this case a smaller displacement motor crippled by even less air and a huge drag/resistance load waiting to be overcome by the boost you cant effectively make to begin with.
I bet that setup would rip with stock turbos or a 59/72. If you have to run a single get an s362 and see what spoolup is with a single.
