question/tips/tricks/advice/how to thread
Tom@BigTimeKustomz
Bayville, NJ
2013. It will not work and say "go to dealer," but then will work fine. Other day I gave truck a much needed bath and it was watching porn through the squiggly lines hazy, then it was fine. Pain in the neck to pull apart? I'll do that this weekend if it's easy.
zporta
I mean where the connection from the tailgate to the harness is. Should be able to get to it from under the truck.
ChitownPS
When you shut off advanced trac. Does it come back on automatically when you shut the truck off and restart it? Or do you have to hold the button down for 5 secs to turn it back on?
Sent from my SM-N920P using Tapatalk
automatically resets itself
put the truck in park, hit the lock button on the key 2x then the remote start button 2x turn key to off, remove key, truck should still be running at this point
Does not work for me... Oh well
redneck1
Nor Cal
Could start a new thread, but this looked like a good spot. Just found easy way to change TPMS sensor pressures. It worked for my brother and me, curious if it fact works for everyone.
But you air your tires to where your tpms light is off. Park for a couple hours, just so the tpms sensors go to sleep mode, then let your air out to your desired pressure. Let mine sit over night after that, and no light. Went from running 75 psi with no light to running 60 psi still with no light. Just make sure no light on when you parked, and park for a few hours. Then do your trick. I think time is the key. No special tools or ids used. This may be listed somewhere, but i have searched and never found any good solutions. Let me know if it works for you. FYI, my truck is a 16 and his is a 15.
bigblzr94
OC
check your door tire id you may only have a truck set to 65psi. so the light would not come on at 60psi.
redneck1
Nor Cal
The light was coming on about 72 psi or so. My door says 80 psi rear and 75 psi front. I'm not saying it works for all trucks, because I don't know. But I'll vouch for 2 trucks that it worked on. I just thought maybe someone had tried it.
LovetheTide
Fort Worth
What causes this? Will I be ok driving it? Got about 300 miles I have to drive today. ImageUploadedByTapatalk1457618444.950049.jpg
how many miles have you driven since this? my experience is that is can take up to three days to come back on...
What causes this? Will I be ok driving it? Got about 300 miles I have to drive today. View attachment 42596
is it just the lighting ir is your coolant tank full to the top? and i have no idea why it would do that... holy crap.. almost looks as if its sucking it flat some***inhow!
LovetheTide
Fort Worth
Yea it's pretty damn full. Need to take care of that soon.
I last checked everything probly two weeks ago and the hose was fine. No idea what happened
whoa... im guessing the water pump is sucking it flat and pushing it into the tank. but i have no idea what way the flow is on the coolant system.. something must be plugged. does it release when you take the cap off the coolant tank?
LovetheTide
Fort Worth
Warmed up and it's back to normal. Not sure what the deal is.
I'll remove some of the extra coolant and watch it for a few days. I'm sure I'll end up being a new hose soon though.
