The Next Chapter
dcswetman
Girard, GA
not to make it worse , but the interiors absolutely put the 13-16 on blast .
I've been staying away from the dealership for that very reason. If I ever sit my arse in one it will be over. Just from the pictures I've seen they look incredible. Yours is definitely the best looking one I've seen and if I do get one I may have to pull some ques from yours. That blue is amazing
jimdawg185
we got the intercooler for the 2017 test fitted , it requires a cold side pipe extension , which is included with the kit. ive immediately noticed .5+ mpg gain and significant throttle response and low end power. i'm very shocked at the performance increase so far.
So with your ic can I still use the H&S pipe upgrade? Because that IC is next.
Martin #6
Truckee, CA.
Was wondering about IC and H&S pipe compatibility also. Will they work together?
