dsmracing1
Alberta, Canada
Rhino lined up underneath the truck. Looks brand new again!
Tn
CCV re-routed out of the intake and powder coated the pipes, and spider lots of soap and water. Blueberry with metallic.
Connor M
Masshole
Dropped the tank yesterday and found my issues with fueling. Screen was smashed and the pieces were getting stuck to the end of the pickup. Nobody had parts in stock so I'm waiting on rock auto.
I don't even know how that happens.
Tn
I ran it down and hid it behind the frame away from the weather. I didn't bother with a catch can. Same as I did years ago on my 99. You smell it every now and again but that doesn't bother me.
ToMang07
Mainah!
Ball joints, u-joint, and warn hub on the passenger side today. Hopefully the drivers side goes easier tomorrow.
Sent from my SM-G960U using Tapatalk
C2tuck
North Texas
Stripped down the extra front bumper I picked up a couple months ago and took the rear chrome caps off the back. Having them stripped I the morning, then all off to the powder coated to get coated PTM. Grille surround should be done getting painted in a couple days. Then reassembly. Pics to follow.
Mesa, AZ
Did this plowing today.
You got lucky... Seen a bunch rip the snout off the transfer case when they bind up... Then its new driveshaft and new transfer case. Maybe some new trans parts as well depending on how hard it came dislodged.
ToMang07
Mainah!
Im aware I'm "lucky" in that sense.... still...WTF Batman! Lol
It popped out right after I broke and pushed back a frozen snowbank...i immediately stopped, got out and unlocked the hubs and put it in 2wd.
I just can't figure out why it happened. All the u-joints were fine as well as the cardan. Only thing I can figure is a clip somehow got dislodged or prematurely rotted through and it threw the cap. I rebuilt it less than 3 years ago.
Connor M
Masshole
Holes on the balancer were egged out and two bolts were snapped off. Replaced with new oem pulley and arp bolts.
Replaced that tie rod too, and I’m waiting on bj’s.
ToMang07
Mainah!
All in all one of the easiest jobs I've done on this truck.
ToMang07
Mainah!
What the hell did you bend that ***ker on?
Connor M
Masshole
No clue, was like it when I bought the truck.
Had it up on my rollback a couple weeks ago and noticed it. But it was going fast and hit something very strong for sure.
DEEZUZ
NO PUKESTERS
NWI
once a year oil change and fuel filters.
also kicked off the last 2 running board mounts... trucks rusted out badly.
also looked at my leaky oil cooler and looked at my leaky tstat housing.
for another day....
