‘10 6.4 rebuild
Dieselnewb64
Detroit
Hello all new diesel owner here,
I purchased a 2010 6.4 with a few upgrades, deleted, and tuned. No it’s not studded. I thought I knew enough to take on this motor and I bite off a lot! I will not admit that it’s to much I live this truck! But I just got a motor for $1000 and I want to rebuild this properly as it’s my project/enjoyment. It has a OEM block, crank, pistons, cam and head. I am looking at KDD steel pistons kit and the “stage 2.5” set up. This is my daily. I know i didn’t go the best route, so I’m looking to you guys hoping to get some assistance with tools needed besides basic, computers/scanners, and all the tips a tricks. I bleed blue and I love my fords. Any knowledge or advice would be greatly appreciated.
Powerstroke Cowboy
Montana
What is your goal for horse power?
What do you plan to use the pickup for?
Putting 6.7 pistons in is for most folks a lot of money spent that was not needed.
Dieselnewb64
Detroit
I’m hoping for 500-600hp but have the ability to 800. Mind you I realize that in order to get to the higher Pony’s that I need different transmission mods, wheels ect. To do it safely but then it’s leaning into track use. I’m not trying to run from cop or any illegal street activity.
This is my project/daily/man cave. Also I live right off Woodward in Detroit, I like to have appropriate fun and Cruz during the nice weather. But this is my pride and joy. I still want to have the ability to tow with the cool factor.
From what little experience and knowledge I do have this motor suffers from some rush engineering and manufacturing problems bc of emissions and what not(in my opinion). The steel 6.7 pistons seem like the answer to the pistons cracking while increasing mileage and longevity. I’m open to suggestions my primary problem is I for machine work I have to seek out others for that. I want to do as much work as possible myself.
I hope I answered your questions.
Powerstroke Cowboy
Montana
I would personally use coated maxxforce 7 pistons with billet rods.
Run a set of KC drop in turbos. With the stock hpfp and injectors that will get you over 600 to the ground with the proper tuning. If you want more HP just add bigger injectors and a dual hpfp setup.
Put a mild stage one cam in it and a set of kdd heads if you want to up the efficiency of the setup. Add the appropriate valve springs and pushrods. You could also add a ported intake while you have it apart.
A no limit intake would be good as well.
I better intercooler and piping would be good as well.
Mesa, AZ
^whs I couldn’t have said it better myself. Our test truck is a 2010 Harley 6.4, and with dual k16s, 100% injectors, and our 59/80 drop in turbos we’ve done over 1000 to the wheels, not something we’d recommend long term, but doable. Given this is on a fully built kdd long block, with max force pistons I believe, it was before the steel piston 6.7s were out, definitely before Jared did his magic to make them work in other motors. Easily be over 600 with just good tunes and drop in turbos.
Dieselnewb64
Detroit
Ok I already like the suggestions. :) forgive my ignorance with this question: is deliped a focus point I should consider? Do you have a company that you would recommend?
Also my current setup is not the factory “twin turbo” set up. I believe it’s a single turbine turbo. I had my eye on the kc drop in compound turbo.
Powerstroke Cowboy
Montana
Do you plan to run the pickup in the winter? What do you see for winter temperatures?
Personally I would not delip the pistons if your gong to keep stock fuel, even up to 800 you shouldn't have a problem, unless your the kind of guy that is constantly mashing the pedal.
I've never heard of a dual turbin turbo, as far as I know all turbos are single turbine.
Do you have a couple of under hood pictures of the turbo location?
The 6.4 was equipped from the factory with compound turbos. A larger feeding a smaller on the compressor side.
Dieselnewb64
Detroit
I can get you some tomorrow, but at this time it does not have a compound turbo. Idk about constantly mashing it but I do have some fun in it. As far as winter I’m in Michigan so the weather man can’t even give you an accurate forecast, I drive this thing everywhere if I’m being honest.its my pride and joy/mancave. Noted on the Delip, a lot of the sites I visit recommend it, I appreciate the heads up. As far as fuel I have to be honest I didn’t know there was fuel outside of regular highway grade diesel(ULSD).
Mesa, AZ
Stock fuel refers to stock injectors/hi pressure pump.
Personally, I’d delip the pistons, helps reduce the chances of cracking, however, does increase white smoke on cold start, and maybe some cold idle characteristics. My 6.0 is delipped and has valve reliefs, smokes pretty good on cold starts, but cleans up within 45 seconds to a minute, however, Az cold is not Michigan cold.
Dieselnewb64
Detroit
Thank you for the clarification lol I was in a full blown panic and back to the interweb double checking my knowledge base. As of now I’m told that the pistons and crank are oem no coating or delip and I get some white smoke in the am. I figured it’s just diesel being stubborn bc it’s cold. Should I be concerned?
I’m still working on the pictures of my setup, work has me going in when it’s dark coming home when it’s dark😒. Also if anyone has some input on engine lifts(cherry picker)and engine stands I would appreciate anything at this point. I don’t do this for a living but this is my investment/hobby, will I be safe with a Pittsburgh for now(meeting weight necessitates).
Mesa, AZ
I’m still working on the pictures of my setup, work has me going in when it’s dark coming home when it’s dark[emoji19]. Also if anyone has some input on engine lifts(cherry picker)and engine stands I would appreciate anything at this point. I don’t do this for a living but this is my investment/hobby, will I be safe with a Pittsburgh for now(meeting weight necessitates).
Little bit of white smoke with it being cold isn’t really anything to worry about. If it looks like you’re fogging for mosquitoes or something, then I’d worry.
I use a Pittsburgh cherry picker both at home and at the shop, they work. Definitely not really worth 10x the price for a good one. One at the shop is used fairly constantly and is like 7 years old, maybe even older. As far as engine stands go, I personally like the ones with the single leg in the middle, as you can get the motor on it easier, the 2 leg ones don’t fit between the cherry picker legs. I think the ones we have are harbor freight, not positive though. The boss did find someone who is making adapters for the engine stand that fit in the engine stand, and mount to the motor mount holes. These engine stands work, not the greatest choice, but they do work. Probably the best I’ve used was the otc ones at the dealer, with the 6.0/6.4 motor mount adaptor plates. However, last I checked, you’re looking at close to 5k for one of those.
Dieselnewb64
Detroit
Finally got some pics guys sorry for the delay.
Powerstroke Cowboy
Montana
You definitely have a single turbo. That could account for some of the cold smoke.
That things had a lot of work done to it.
How many miles since the new motor?
Mesa, AZ
As powerstroke cowboy said, that’s definitely a single. Being a 63mm, do you know the turbine housing size/turbine wheel size? 63 seems small for a 6.4, especially with the air these things can move. The white smoke can be a leaking seal on it, possibly from excessive back pressure if it has a tight turbine housing and a small turbine wheel. Unfortunately, in order to get non vgt turbos to drive decent on 6.0s and 6.4s they have to be pretty small on the turbine side, otherwise they’re a smoke show, and you need a calendar to time spool up.
Dieselnewb64
Detroit
I’m not sure how to get this information. Is there a way to take a picture to help or will I have to remove it?
Powerstroke Cowboy
Montana
Nice. Should be good for a long time yet. I did notice on the build sheet there's no mention of head studs. Do you have the ability to monitor exhaust backpressure?
Look for the tag on the turbo. Plus, on the turbine housing (exhaust side) right where it bolts to the up-pipes/pedestal there sould be some numbers. One will be the A/R of the housing. Like A/R .83 or .90
Dieselnewb64
Detroit
There is no head studs I want to put them on bad! However, my concern is with it fully assembled seems like I’m going into a bad neighborhood.
The only tag I found was the this:
Also as mentioned above about the single turbo, should I go back to compound?
Also please guys forgive my ignorance in this matter. With what mods I have on there I feel like I’m not doing something or I’m assuming the parts are for something I’m not doing. I would like to install an interface/hud/diagnostics component to help me track what’s going on. Also I’m looking for information on the right computer hardware for someone like myself that puts me in a good position to do my own maintenance and work. As far as programming I don’t feel confident in that at this time so unless there’s a place to help me understand(read up on) than I don’t want to go overboard.
Powerstroke Cowboy
Montana
You can do headstuds one at a time. There's a right-up on here by BIGRPOWER (Mike) I'm not 100% sure I got the user name right. I did mine one at a time years ago. What a pain. Yo7 have to jack the engine up to get the rear bolt and and stud back in.
The Turbo you have has the bigger of the two turbine wheels offered in that turbo. Yours has the 73/80mm turbine wheel. The smaller on is 68/76mm. You will have to look at the turbine housing to see what size it is. It's stamped right into the housing.
If your pickup is a daily driver and you tow with it compounds can not be beat. This is my personal opinion. Properly tuned and with the right compound setup from KC turbos you will have north of 600 hp closer to 650.
I'm not sure what's out there for electronic gauges. I just use the minimax display.
If your looking for diagnostic software, use ForScan. You just need a laptop and cable. The download is free.
I would recommend finding a good tuner. if your not familiar with diesels and how tuning works your better off letting the pros do it.
I did notice on the paper you have free tune updates for life. That would depend if the company that tuned the pickup is still offering tunes.
