wanna run mid 13s
davey99ps
Waterford WI
Using the hp calculator, you need roughly 400hp to hit 13.5 in a 6000lb truck. You should easily hit your goals with the mods you have plus electric fuel and a bts. Like I said, if your trucks running good, an hooks, you should have no problems going deep into the 13s
davey99ps
Waterford WI
i might even be switchin to 238/100s from rosewood im ganna send mine in
If that's the case, you'll be knocking on the 12 sec door. That's 1 of the nice things about the obs, they're light which makes it easier to go fast. Even my land yacht (cclb) can roll across the scales under 7 with just a little work
97spoolinstroker
brighton colorado
davey99ps
Waterford WI
What turbo is that? Do you have any specs on it? You can pm me the info if you, I might be interested if its for sale
97spoolinstroker
brighton colorado
its a custom built turbo its a 102 over a 92 i think or somthin close to that i know its a 102 mm compressor just cant remember exhaust but the thing is custom built for a work stock pull truck
DIESEL SHOP LLC.
GRISWOLD, CT
12.649 @ 110 or 111 on spray best time on fuel 12.90s around 102 103 mph. thats with a bad 2nd to 3rd shift. truck makes 520 h.p. on fuel 655 h.p. on spray. With a d66 and a waste gate. a d66 is small for my setup but works well on the street.
