superduty prerunner project
shmoozer
Yeah it looks like you've got a few more important things to take care of right now lol
Cutting-Edge Diesel
Newkirk, OK
well the bumper is getting powder coated at the moment and should go out tomorrow.
the tire gate was delivered the 28th and signed by someone I dont know.... wonderful. they are trying to track it down right now.
Cutting-Edge Diesel
Newkirk, OK
Got the kit 95% done tonight. All I lack is the sway bar links. Carli says they need to be adjusted to be perpendicular when at ride hight. But that are past that (like they are to long) and its as short as it will go. Going to have to call them tomorrow.
Got the pump plumed and wired and fuel pressure set. I was going to back it out of the shop and get some better pics but I remembered I still had my down pipe out from installing the shock soooo that will happen tomorrow,
Cutting-Edge Diesel
Newkirk, OK
ill just leave these here
6.0newb!
somewhere in the ocean
Man that things looks friggin sweet!! I wasn't sure about the chrome methods at first but now it's really growing on me! You take it for a test drive yet?
Cutting-Edge Diesel
Newkirk, OK
No :( going to have to some major work on the pass side. Shock hose is touching the down pipe. So I'm going to have to move the down pipe or rotate the fitting on the shock. Then find a place to mount the reservoir. PITA
JMart
DFW
Looks like you are missing lugnuts. Did you just throw the fronts on for a photo opp?
Cutting-Edge Diesel
Newkirk, OK
couple more pics. and one of the problem area... but I got parts to rework the down pipe so It is getting moved little farther out away from the shock.
