Swagger Build thread
rat49f6
Vernon,NJ
Likely stay with factiry obs alcoas for a while but no bigger than 20s
Sent from my SGH-M919 using Xparent Green Tapatalk 2
rat49f6
Vernon,NJ
Swagger is a roller for the first time in over 3 years!!!
Full lift...
Lowered... it eill go much lower once I clearance the fender supports
Ad8 PRODIGY
Orange County, NY
Yep. Front and rear of the pinch welds touch and all between them. Ride height is only set with a ball valve and shop air so don't judge it too closely.
rat49f6
Vernon,NJ
More pics taken from the same perspective as each other
Full lift
Fully down... pinch weld lays from front to back
TrailerHauler
Michigan
Forgive me if it was already answered earlier in the thread, but what are you using for a compressor/ tank combo?
rat49f6
Vernon,NJ
Im gonna convert the a/c pump into a compressor with a 12 volt back up
Air tanks will be a 8 gallon and a 12 gallon under the bed
TrailerHauler
Michigan
That sounds like a good idea to me. I would like to get a belt driven compressor for onboard air, but there are little to no options at a reasonable price that leave the a/c in tact.
How are you going to lubricate the compressor without freon running through it any longer?
rat49f6
Vernon,NJ
Nope no need for it and the heater box was kinda in the way of the tire
rat49f6
Vernon,NJ
Tool oiler in the intake side and a oil/ water separator after the pump to remove the unused oil
Couldn't fab something to fit where the second alternator would go?
TrailerHauler
Michigan
Awesome, keep up the great work!
Probably, theres room next to the top alternator to. I guess I just don't really NEED that much air to put something together. I'm looking forward to seeing how rat's comes together using the A/C pump.
rat49f6
Vernon,NJ
Riffraff sells a kit the pump is affordable the bracket is a lil pricey
