KC 68mm Stage 3 vgt turbo
05str6.0ker
Ok that makes sense. i figured it was something simple but just goes to show how much i know. yall dont want to run any more testers do you?! haha
KCTurbos
We now have a couple of .72ar race covers out there being tested. So far the results are coming back very positive. We hope to get some dyno/track numbers coming in soon.
Here is a pic of the cover on a customers turbo
KCTurbos
Here are a couple of pics from some recent customers sporting our polished .72ar covers.
KCTurbos
Here is a track video...
2005 F250, 175/30 Warren Injectors, KC 68mm stage 3 turbo, WPE ported intake, Warren Diesel Comp Plus Trans, 35" bfg tires, stock 3.73 gearing.
Ran 8.625 @ 80.08 mph in 1/8 mile.
Weight was 8420lbs (truck was loaded with tools and parts)
https://www.youtube.com/watch?v=k6d9TDU7NL8
KCTurbos
We also offer a 100% brand new turbo. I will probably start a new thread on it
$2200 with no core charge
mind if I smoke
Knoxville, TN
Just got my 68mm in last night and so far I'm loving it. I plan on getting some dyno numbers and videos up here in the next few weeks. Charlie, thanks for everything. I know I asked allot of questions, but I am very confident that I made the right choice by going with your turbo.
TALLBOY
Hey, I'm new to this forum. My names Adrien. I just recently bought this KC turbo stage 3 with the .72 race face. I have 205/50's and love this setup. As you can see my truck is the best of both worlds. Fast and big.
TALLBOY
Watch "F250 6.0/ KC 68 mm turbo stage 3/ H.D.'s 205/50's" on YouTube
F250 6.0/ KC 68 mm turbo stage 3/ H.D.'s 205/50's: http://youtu.be/Co2WWcSpmBg
I'm not sure how to add or link this video. But it's my truck showing the Bad Ass sound of this turbo. Again I love it!
TALLBOY
I'll also post my dyno results after I get back over to PHP to do my dyno. I've been playing with my fuel psi and I'm now down to the fact I need a RR. So when I get that I'll go back and get it done. :D:D:D:D:D
djberg
sounds sick, sharp truck saw it on the php facebook. very purdy
2Dstorm
I'm running 175/75 warrens with upgraded solenoids and a few other mods my truck is a dually with 4.10's and 35" tires. How much weight can I tow SAFELY with the 68mm turbo? Also what other supporting mods would be needed to keep the egts low?
KCTurbos
the 75% nozzles are going to need a lot of fuel pulled. DONT TOW ON A RACE TUNE. Even if you can keep egts under control you still have to worry about heavily advanced timing causing really high cylinder pressures.
I would get a really good tow tune. Remove any FICM tunes you have. Then try to keep the rpms above 2000-2200. Have your tuner move your shift point on OD way up so you don't shift into it too early. Have him hold the each gear a little longer than normal. Also make sure he has a pretty aggressive VGT duty cycle to make sure to stay on top of the turbo. You dont want to be at 1600rpms in OD because temps will creep up on you.
Try to keep temps under 1250 egts. You can go higher than that for small bursts (like 30seconds to 1min) but you don't wanna keep it up higher than 1250 for too long.
I have had many guys pull max weight with the stage 3 (around 20,000 lbs). Temps were a little high but still in the safe zone.
2Dstorm
Thanks for your quick reply, I've been talking to Nate about this upgrade for a few months I'm just not sure what to do. 68 kc,a stage 3 intake, and steed speeds and nates uppipes. I'm trying to clean up the injectors and gain a little power at the same time but I want a reliable dd. I run the raped ape tune from drew at brp. I also have a tow tune from drew aswell.
KCTurbos
Nice Job Eric!!! That's a good time and the truck runs pretty clean down the track. Take off the lift, throw on some stock sized tires, load up the full fuel race tune and you might get into to the 12s! I bet your friend was pretty disappointed when your giant truck beat his STI at the track
13.3 @ 101mph
8250lbs
KC68
Warren 190/75s
Lifted on 35s with stock gearing
https://www.youtube.com/watch?v=kbSguZ9njxU&feature=youtu.be&list=UU-Oii_RgMB8MODvLe21MPnQ
http://youtu.be/kbSguZ9njxU?list=UU-Oii_RgMB8MODvLe21MPnQ
valvetick
13.3 @ 101mph
8250lbs
KC68
Warren 190/75s
Thanks Charlie! Truck did much better then I expected when I went to the scale I was thinking it would run much slower. Ya he had some excuses and said to wait for his new turbo but he was a pretty good sport everyone else was harder on him when they saw the video. Again thanks for all your help you went above and beyond what anyone else would.
