What do you want pics of? Here's what I believe to be 6.4 hg part number.Pics please.
Gentleman, I've had a fairly bad experience with dynamite diesel performance and machine when it comes to sourcing my rebuild kit. The kit they sent me had mostly 6.0 stuff in it. I first noticed they failed when I tried to install the 6.4 rod bearings in the 6.0 rods. (Crossed referenced the number and found out they were for the 6.4) I got on the phone and they made it "right" quickly. While on the phone I also had them check other part numbers. Come to find out the gasket sets were also for the 6.4. (Side note: I also ordered ford oem head gaskets with the kit as well.) Tonight I noticed they didn't swap out the mahle head gaskets for the ford oem(that I paid 150 extra for).
I really wanted to set these heads this weekend. What risks do I run with running the mahle head gaskets? I'm calling ddpm tomorrow morning to see if they will overnight me a set of oem at their costs.
Im just frustrated and venting.
Sent from my SM-G970U using Tapatalk
Was prepping for the oil pan, and noticed these 2 alignment dowels. I dont remember removing anything from these. We're these for factory machining, or have I lost my mind and misplaced something that goes there? View attachment 187601
You can always come to logansport and help a guy out. LolI'm extremely jealous. Been doing these builds for 15 years and never has one been for myself.
I'll see what I can do on the syrup.I wish I could man, id pick up more syrup
We need more pics my man.
Fluidyne cooler.I'm just joshing ya.
That bpd remote cooler?
Fluidyne cooler.
I'm also making some fun things for this engine and will be building a top plate in place of the factory oil cooler/filter setup. I have limited 6.0 experience. Looking at some oil flow diagrams, it appears that the cavity in the engine valley(beneath cooler/filter),is actually the reservoir for the hpop system which see full engine oil pressure, correct? Assuming this reservoir sees full engine operating pressure, other accessories that require oil supply can be fed from this pressurized reservoir?
Been eyeing the bpd plate, and I like it, but would like to make some variations from it.
Learned some lessons on installing this engine. I never pulled the converter after I removed the engine, but apparently the converter got disengaged from the transmission pump gears. When I went to mate the engine to trans I thought things went together ok, alas no. When I got them mated I tried to turn the engine over and it no go, so atleast I didn't get too far along.
I figured since I never pulled the converter it would still be mated properly....nope. I must have pulled it out just a bit to disengage the pump. Anyway, I got new gears and some seals for the front. Had to drain the trans and pull the filter to remove the front portion of the trans. I think the trans filter seal is stuck in the pump housing(see pic). It's the reddish ribbed seal that I thought normally gets replace when dropping the filter. It seems really stuck in there. I already poked it with a pick, so now I feel I have to remove and replace it. What's the deal with this seal?
Also threw in pic of smushed pump gear.
Live and learn.View attachment 187663View attachment 187664
