11s in the 1/4
Dieselboy.
Surrey B.C.
Yes, you will have less shock to the drive train / engine if you have two stages installed. Traction will determine the 1st stage and over all volume will determine the remaining jet size.
OK thanks. I will probably start with .067-.076
Blowby
Start with .067 if that's the size jet you have. Moving to a .076 will be noticeable. Keep the bottle pressure correct.
Vader's Fury
Chesapeake City, MD
Most starter kits come with multiple jets. Just look at the range that comes with the kit before you buy it. I wouldn't go by the hp numbers they give for different jet sizes either, I would stick with the decimal numbers.
