C2tuck
North Texas
Sean,
Can I get a price for a rear power door lock actuator and rear view mirror for my 15 f250?
Thanks
sunrisefordparts
Sean,
Thanks
Hi,
Passenger side rear actuator: $30.71 ($50.70 retail)
Driver side rear actuator: $52.87 ($87.38 retail)
mirror: $591.29 ($895.90 retail)
+ shipping
thanks,
Sean
q650307
bowsniper
Wrong part sent
Hi Sean,
I'm installing ACC (automatic cruise control) in my 2020 F350 Lariat and I ordered the parts from Sunrise webpage on May 27, Invoice #1142986. There is a problem with the distance sensor assembly HC3Z-9E731-A for $597.27. The PN on the box is correct, but the PN on the part is HC3T-9G768-AD. How can I get this returned for the correct part?
Thanks,
Mark
sunrisefordparts
Hi Sean,
Thanks,
Mark
Hi Mark,
HC3T-9G768-AD is Ford's engineering number for part number HC3Z-9E731-A... it is the same part.
Hope this makes sense...
thanks,
Sean
bowsniper
Sean, the connector on the HC3T-9G768-AD does not fit the connector on the harness, LC3Z-15K867-A.
Thanks,
Mark
sunrisefordparts
Thanks,
Mark
Hey Mark,
Everything I am seeing shows that these two part numbers should be correct... Is there any chance you have a VIN for a truck already equipped? Also, I am not sure that this is even something that can be added, most of the new electronic equipment is controlled by the BCM which may not be able to "see" an add on...?
