sunrisefordparts
Hello, I need a 6r80 lead frame for a 2011 f150. I'll pm you my email if you could please send me invoice there.
Hi,
your cost on it is $130.90 + shipping ($198.33 retail).. unfortunately, it is currently on national backorder with no ETA at this time...
Sorry,
Sean
q728246
brewer
Hi Sean, looking for the cigar lighter luminous ring for the dash ashtray pull-out for a 2011 Lincoln Town Car. The luminous ring is green in color.
Thanks,
Brenden
sunrisefordparts
Thanks,
Brenden
Hey Brenden,
Unfortunately that one has been discontinued by Ford... The part number was 3W1Z-15K040-BA
thanks,
Sean
UNBROKEN
I've got a weird one. I'd like to check pricing obviously but mainly availability....actually getting all these parts in one place is the kicker.
This will be all the parts for a 2020-current Lincoln Aviator rear center console. Colors and trim finish is noted and it looks like separate PN's for the different colors so I think I'm good there.
1. Console Assembly Base LC5Z-78045A36-AK
2. Mount Bracket LC5Z-78045B34-A
3. Mount Bracket Bolt (X4) W719498-S451
4. Seat Belt Assembly Screw (X2) W505286-S439
5. Front Panel ebony LC5Z-78045E24-AL
6. Rear Panel ebony LC5Z-78045E24-DE
7. Compartment LC5Z-78045A36-BB
8. Side Panel right ebony LC5Z-7804567-AE
8. Side Panel left ebony LC5Z-7804567-AL
9. Finish Panel without metallic LC5Z-78045A76-EC
10. Front Trim brushed aluminum LC5Z-78045A76-AA
11. Front Trim Mat LC5Z-78045G34-DA
12. Front Molding LC5Z-7804567-AN
13. Rear Molding ebony LC5Z-7804608-BE
14. Storage Compartment LC5Z-78045C22-BA
15/16/17. Cup Holder Insert LC5Z-7813562-AA
18. Utility Tray (X2) LC5Z-78045N28-AL
Plus any HC1, HS1, HN1, HS2 and HB2 screws and clips needed for assembly. I can't find a count for those online anywhere.
Thanks
sunrisefordparts
Thanks
Hi,
1. Console Assembly Base LC5Z-78045A36-AK : $146.14 3-5 days lead time to us
2. Mount Bracket LC5Z-78045B34-A : $143.33 3-5 days...
3. Mount Bracket Bolt (X4) W719498-S451 $2.07 each 2-3 days...
4. Seat Belt Assembly Screw (X2) W505286-S439 $2.07 each 2-3 days...
5. Front Panel ebony LC5Z-78045E24-AL : $58.66 3-5 days..
6. Rear Panel ebony LC5Z-78045E24-DE : $34.07 3-5 days...
7. Compartment LC5Z-78045A36-BB : $563.40 on national backorder...supposed to be released 11/4/22
8. Side Panel right ebony LC5Z-7804567-AE : $87.13 3-5 days...
8. Side Panel left ebony LC5Z-7804567-AL : $87.13 3-5 days...
9. Finish Panel without metallic LC5Z-78045A76-EC ; $244.00 3-5 days...
10. Front Trim brushed aluminum LC5Z-78045A76-AA : $210.49 3-5 days...
11. Front Trim Mat LC5Z-78045G34-DA : $12.74 3-5 days...
12. Front Molding LC5Z-7804567-AN : $64.60 3-5 days...
13. Rear Molding ebony LC5Z-7804608-BE : $131.40 3-5 days...
14. Storage Compartment LC5Z-78045C22-BA : $27.14 3-5 days...
15/16/17. Cup Holder Insert LC5Z-7813562-AA : $113.00 3-5 days...
18. Utility Tray (X2) LC5Z-78045N28-AL : $32.80 each 3-5 days...
all of the following come in packs of four..
HC1: W719592S300 $1.52 each (x8) 1-2 days...
HS1: W506943S424 $.89 each (x4) 1-2 days
HN1: W710609S439 $1.52 each (x4) 1-2 days
HS2: W710609S439 $1.52 each (x4) 1-2 days
HB2: W711158S439 $.89 each (x4) 1-2 days
grand total would be $2042.66 (+tax if you are in California) + shipping
thanks,
Sean
q732285
UNBROKEN
thanks,
Sean
q732285
Not in CA for the tax. I know it's a lot of stuff....is it possible to calculate shipping this early so I can pay all at once?
LaPorte, TX 77571 business address.
sunrisefordparts
If you DM me your email, I will email you the quote through our online ordering system...
UNBROKEN
Hi,
thanks,
Sean
q732285
Sean...I made a slight mistake. I forgot the #18 Utility Trays have a left and right side.
LC5Z-78045N28-AL for the right side and LC5Z-78045N29-AL for the left. I listed two right sides. Can you eliminate one of the 28-AL's and add a 29-AL please?
Thans and sorry....lemme know if I owe a difference.
sunrisefordparts
No problem, we will get it fixed for you.
sunrisefordparts
We double checked it and are coming up with LC5Z-78045N28-AE for the RH and LC5Z-78045N28-AL for the left... Pricing is the same.
kleake
Sapulpa, OK
Needing price for a backup camera for 2011 Explorer Limited. These seem to be all too common and this one has been replaced before and is failing again. You would think there would be a recall similar to the Superduty.
sunrisefordparts
Hi,
You never know, they may issue one on it eventually. If they do, just take the invoice for it to any dealer and you can get reimbursed...
camera: BB5Z-19G490-A $345.33 ($523.23 retail) 2-3 days for us to get.
thanks,
Sean
q732382
UNBROKEN
Sean....I need to add 2 packs of these as well. They're the little hooks for the rear side panels of a new Explorer. lb5z-78550a82-ab
